Up to 20% off select tools
Bike Chain Replacement
Views: 1K
View statistics:
Past 24 Hours:
7
Past 7 Days:
37
Past 30 Days:
160
All Time:
1,024
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Inner and outer plate pairs that are fastened together with pins form chains. In the end, your bike's chain engages the gears. Your bike is probably unrideable if a chain is out of balance. These are some of the most typical issues with bike chains, along with solutions.
    1. Bike Chain Replacement, Pick up the slipped chain and position: step 1, image 1 of 1
      • Pick up the slipped chain and position it to the top of the correct gear while pedaling.
      Ask FixBot
    2. Bike Chain Replacement, Release the derailleur and push the pedal forward: step 2, image 1 of 1
      • Once the chain teeth are locked in place, slowly release the derailleur and push the pedal forward to move the back wheel.
      Ask FixBot
    3. Bike Chain Replacement, Continue pedaling: step 3, image 1 of 1
      • Continue pedaling until the rest of the chains are fit back into their original positions
      Ask FixBot
      • Before you get back on your bike, shift to the lowest gear and continue pedaling. This movement should realign your chain and lock it back into place.
      Ask FixBot
    4. Bike Chain Replacement, Reminder: step 5, image 1 of 1
      • Changing gears without pedaling can cause the chain to bind up, and should be avoided.
      Ask FixBot
Author
with
Camara Dylan
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 160
All Time: 1,024
