Up to 20% off select tools
Bicycle chainring replacement
Views: 5K
View statistics:
Past 24 Hours:
7
Past 7 Days:
68
Past 30 Days:
324
All Time:
4,987
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Do you have an old bike that needs to be restored? A bike’s chainring is one of many things that can be easily worn down as bikes age. A chainring connects the bike chain to the rear wheel of the bike. Restore a bike’s old chainring by replacing it with a new chainring.
    1. Bicycle chainring replacement, Chainring: step 1, image 1 of 1
      • Unscrew both nuts on opposite sides of the rear wheel with the 15 mm wrench until the wheel loosens from the bike frame.
      • Loosen the nuts with the 15 mm wrench and continue unscrewing the nuts with your hands.
      • Push the rear wheel forward until enough slack is given on the chain.
      Ask FixBot
    2. Bicycle chainring replacement: step 2, image 1 of 2 Bicycle chainring replacement: step 2, image 2 of 2
      • With the slack previously made, remove the chain off the chainring.
      • Touching the chain isn't dangerous, but it will be dirty.
      Ask FixBot
    3. Bicycle chainring replacement: step 3, image 1 of 2 Bicycle chainring replacement: step 3, image 2 of 2
      • Locate chainring, the gear connected to the pedals.
      • Place the spanner tool on the backside of the 6.5 mm chainring bolt. The spanner will be used to keep the bolts in place while unscrewing them on the opposite sides.
      • On the chainring there will be one bolt facing the opposite direction, usually the bolt blocked by the pedal. Adjust for this by swapping use of the hex key and spanner tool.
      Ask FixBot
    4. Bicycle chainring replacement: step 4, image 1 of 1
      • With the spanner tool on one side of the chainring, use a 5 mm hex key to remove the chainring bolts on the opposite side.
      • Repeat with the rest of the bolts.
      Ask FixBot
    5. Bicycle chainring replacement: step 5, image 1 of 1
      • Use clean paper towels to wipe off the chainring bolts. Make sure to wipe off all the dirt and grease you can.
      • Clean thoroughly within the threads.
      Ask FixBot
    6. Bicycle chainring replacement: step 6, image 1 of 1
      • Now that the chainring bolts are clean, apply a pea-sized amount of grease to each bolt.
      Ask FixBot
    7. Bicycle chainring replacement: step 7, image 1 of 1
      • Use your fingers to evenly spread a coat the grease around the entire bolt.
      • If the chainring bolts contain rust, it is recommended to replace the bolts with a new set.
      Ask FixBot
6 other people completed this guide.
Author
with
Jeffrey Tang
391 Reputation
1 Guide authored
Cal Poly, Team 23-5, Green Winter 2015 Member of Cal Poly, Team 23-5, Green Winter 2015
CPSU-GREEN-W15S23G5
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 68
Past 30 Days: 324
All Time: 4,987
