Bicycle Freewheel Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
18
Past 7 Days:
132
Past 30 Days:
470
All Time:
2,394
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing a freewheel is an important maintenance task that can restore smooth pedaling and enhance overall bike performance.
The freewheel is a clutch mechanism attached to the rear hub that allows the bike to coast—letting the wheel spin freely even when you're not pedaling.
Over time, freewheels can wear out, leading to skipping, poor engagement, or difficulty shifting. Whether you're replacing a worn-out freewheel or performing routine maintenance, following the correct steps will ensure a secure and reliable installation.
This guide will walk you through the process of replacing a freewheel, beginning after the rear wheel has been removed from the bike. Along the way, you’ll pick up helpful maintenance tips to keep your drivetrain in excellent condition. With the right tools and a bit of care, you’ll have your bike ready to ride in no time!
    1. Bicycle Freewheel Replacement, Freewheel: step 1, image 1 of 3 Bicycle Freewheel Replacement, Freewheel: step 1, image 2 of 3 Bicycle Freewheel Replacement, Freewheel: step 1, image 3 of 3
      • Before you begin, remove the rear wheel from your bike.
      • Place the freewheel removal tool onto the notches of the freewheel.
      Ask FixBot
    2. Bicycle Freewheel Replacement: step 2, image 1 of 1
      • Use an adjustable wrench to turn the freewheel removal tool counter-clockwise to loosen the freewheel.
      Ask FixBot
    3. Bicycle Freewheel Replacement: step 3, image 1 of 3 Bicycle Freewheel Replacement: step 3, image 2 of 3 Bicycle Freewheel Replacement: step 3, image 3 of 3
      • When it's loose, remove the freewheel by hand.
      Ask FixBot
    4. Bicycle Freewheel Replacement: step 4, image 1 of 1
      • Carefully examine the hub threads for any signs of damage or wear, such as cross-threading or debris.
      • Before installing the new freewheel, apply a light coat of grease or anti-seize lubricant to prevent future issues and ensure smooth installation.
      Ask FixBot
    5. Bicycle Freewheel Replacement: step 5, image 1 of 2 Bicycle Freewheel Replacement: step 5, image 2 of 2
      • Install the new freewheel by spinning it with your hand clockwise until it is snug.
      • You should not feel any tension as this is a sign of cross-threading.
      Ask FixBot
After following this guide your new freewheel should be installed.
David Hanna
122 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 132
Past 30 Days: 470
All Time: 2,394
