Bicycle Cassette Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
12
Past 7 Days:
93
Past 30 Days:
413
All Time:
2,512
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The cassette on your bicycle can get worn down over time. With regular use of the bicycle, including continuous pedaling and shifting, the cassette wears down which then causes wear on the chain and performance issues for the entire bicycle. This excessive chain wear can cause further damage to the chain rings, which can lead to the entire drivetrain of the bicycle needing replacement. To avoid this from happening, replacing a worn down cassette is beneficial as it can extend the lifespan of a drivetrain and lead to a more enjoyable biking experience. This guide will show you step by step how to replace the cassette on any 7-12 speed bicycle.
Before starting this guide make sure that you detach the rear wheel of the bicycle that holds the cassette. Also make sure to have all necessary tools listed in the guide.
    1. Bicycle Cassette Replacement, Bicycle Cassette: step 1, image 1 of 2 Bicycle Cassette Replacement, Bicycle Cassette: step 1, image 2 of 2
      • Place your wheel on a hard surface with the cassette on your right side.
      • Wrap the chain whip clockwise around the cassette.
      Ask FixBot
    2. Bicycle Cassette Replacement: step 2, image 1 of 3 Bicycle Cassette Replacement: step 2, image 2 of 3 Bicycle Cassette Replacement: step 2, image 3 of 3
      • Insert the cassette lockring tool into the center of the cassette with the lever arm between 7 and 9 o'clock.
      • Holding the chain whip in place with your left hand, apply counterclockwise force on the cassette tool's lever arm.
      • Continue turning the cassette tool until the tool spins freely.
      Ask FixBot
    3. Bicycle Cassette Replacement: step 3, image 1 of 3 Bicycle Cassette Replacement: step 3, image 2 of 3 Bicycle Cassette Replacement: step 3, image 3 of 3
      • Lay the wheel down on a flat surface with the cassette facing upwards.
      • Loosen the cassette lockring by turning it counterclockwise.
      Ask FixBot
    4. Bicycle Cassette Replacement: step 4, image 1 of 3 Bicycle Cassette Replacement: step 4, image 2 of 3 Bicycle Cassette Replacement: step 4, image 3 of 3
      • Remove the cassette lockring.
      • Using both hands, lift the cassette in one piece from the freehub body.
      Ask FixBot
    5. Bicycle Cassette Replacement: step 5, image 1 of 2 Bicycle Cassette Replacement: step 5, image 2 of 2
      • Your cassette may require a spacer to work properly with your freehub. Consult your cassette user's manual to determine your spacer needs.
      • Remove the old freehub body spacer as needed.
      Ask FixBot
    6. Bicycle Cassette Replacement: step 6, image 1 of 3 Bicycle Cassette Replacement: step 6, image 2 of 3 Bicycle Cassette Replacement: step 6, image 3 of 3
      • Locate the small cutout on the bottom of the new cassette.
      • Locate the small ridge on the freehub body.
      • Slide the bottom piece of the new cassette on the freehub body by matching the small cutout with the small ridge.
      Ask FixBot
    7. Bicycle Cassette Replacement: step 7, image 1 of 3 Bicycle Cassette Replacement: step 7, image 2 of 3 Bicycle Cassette Replacement: step 7, image 3 of 3
      • Continue placing smaller cogs on the freehub body by matching the cutouts and ridges.
      • Insert spacers as specified by the cassette user's manual.
      Ask FixBot
    8. Bicycle Cassette Replacement: step 8, image 1 of 3 Bicycle Cassette Replacement: step 8, image 2 of 3 Bicycle Cassette Replacement: step 8, image 3 of 3
      • For the final two cogs, locate the small cutouts and place on top of the already placed cogs by aligning with the top of small ridge on the freehub body.
      • The top two cogs will not fully slide on to the freehub body and require more attention for aligned placement.
      Ask FixBot
    9. Bicycle Cassette Replacement: step 9, image 1 of 2 Bicycle Cassette Replacement: step 9, image 2 of 2
      • Place the cassette lockring onto the top of the final cog.
      • Start threading the lockring clockwise into the freehub by hand.
      Ask FixBot
    10. Bicycle Cassette Replacement: step 10, image 1 of 3 Bicycle Cassette Replacement: step 10, image 2 of 3 Bicycle Cassette Replacement: step 10, image 3 of 3
      • Once the lockring is partially threaded in, insert the cassette lockring tool.
      • Tighten the cassette on the freehub body by turning the lockring tool clockwise.
      • The exact torque to tighten to varies by cassette manufacturer and model. Consult the cassette user's manual.
      • After finishing tightening, check the cassette for play by pulling up on the largest cog. If excess play is present and the cassette has been tightened to specifications, a spacer is likely missing.
      Ask FixBot
Finish Line
2 other people completed this guide.
Lars Lundqvist
235 Reputation
1 Guide authored
UC Davis, Team 1-5, Morris Spring 2025 Member of UC Davis, Team 1-5, Morris Spring 2025
UCD-MORRIS-S25S1G5
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 93
Past 30 Days: 413
All Time: 2,512
