Up to 20% off select tools
Beyerdynamic MMX100 Volume Controller Repair
Views: 2.9K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
110
All Time:
2,862
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will illustrate how to desolder the rotary encoder responsible for the volume control on the Beyerdynamic MMX100 headset. If you're experiencing issues with your headset's volume, follow the steps outlined here to successfully complete the soldering process. Ensure you have some soldering experience, exercise caution to avoid potential risks, and use anti-static measures during the repair.
    1. Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: step 1, image 1 of 3 Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: step 1, image 2 of 3 Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: step 1, image 3 of 3
      • Twist the left speaker cushion towards you, and pull off the headset.
      Ask FixBot
    2. Beyerdynamic MMX100 Volume Controller Repair: step 2, image 1 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 2, image 2 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 2, image 3 of 3
      • Using the 2.0mm Phillips-Head screwdriver, unscrew the two 0.6mm screws at the end of the left side headband.
      Ask FixBot
    3. Beyerdynamic MMX100 Volume Controller Repair: step 3, image 1 of 2 Beyerdynamic MMX100 Volume Controller Repair: step 3, image 2 of 2
      • Hold open the top part of the headband. Slide out the left earphone.
      Ask FixBot
    4. Beyerdynamic MMX100 Volume Controller Repair: step 4, image 1 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 4, image 2 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 4, image 3 of 3
      • Using the 3.0mm Phillips-Head Screwdriver, unscrew the three 0.7 mm screws on the left speaker cover.
      Ask FixBot
    5. Beyerdynamic MMX100 Volume Controller Repair: step 5, image 1 of 2 Beyerdynamic MMX100 Volume Controller Repair: step 5, image 2 of 2
      • Using the 2.0mm Phillips-Head Screwdriver, unscrew the two 0.5mm screws on the volume control component.
      Ask FixBot
    6. Beyerdynamic MMX100 Volume Controller Repair: step 6, image 1 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 6, image 2 of 3 Beyerdynamic MMX100 Volume Controller Repair: step 6, image 3 of 3
      • Take out, and flip over, the volume control component.
      Ask FixBot
    7. Beyerdynamic MMX100 Volume Controller Repair: step 7, image 1 of 2 Beyerdynamic MMX100 Volume Controller Repair: step 7, image 2 of 2
      • Using the 2.0mm Phillips-Head Screwdriver, unscrew the two 0.3mm screws on the board. Then, take off the volume wheel.
      Ask FixBot
    8. Beyerdynamic MMX100 Volume Controller Repair: step 8, image 1 of 2 Beyerdynamic MMX100 Volume Controller Repair: step 8, image 2 of 2
      • Hazardous situation which, if not avoided, could result in minor or moderate injury.
      • Using a soldering iron, desolder the damaged wires and the prongs on either side of the board.
      Ask FixBot
2 other people completed this guide.
Author
with
Anthony Grande
205 Reputation
1 Guide authored
1 Guide Comment
I have these MMX100 headphones and I want to attempt this repair, but I was wondering where I could find a suitable replacement part for the rotary encoder.
SoupspoonDx - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 110
All Time: 2,862
