Besta Super 5000 Motherboard Replacement
    1. Besta Super 5000 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Turn the device over so that the barcode is facing upwards.
      Ask FixBot
    2. Besta Super 5000 Motherboard Replacement: step 2, image 1 of 2 Besta Super 5000 Motherboard Replacement: step 2, image 2 of 2
      • Place your fingers on the battery cover arrow and pull the cover down and off the device.
      Ask FixBot
    3. Besta Super 5000 Motherboard Replacement: step 3, image 1 of 1
      • Pull upwards on the battery tab to remove the battery from the device.
      Ask FixBot
    1. Besta Super 5000 Motherboard Replacement, Back Cover: step 4, image 1 of 1
      • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
      Ask FixBot
    2. Besta Super 5000 Motherboard Replacement: step 5, image 1 of 1
      • Remove the two screws behind the battery using a Phillips #0 screwdriver.
      Ask FixBot
    3. Besta Super 5000 Motherboard Replacement: step 6, image 1 of 2 Besta Super 5000 Motherboard Replacement: step 6, image 2 of 2
      • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
      • Gently pry off the backing using an opening tool.
      Ask FixBot
    1. Besta Super 5000 Motherboard Replacement, Motherboard: step 7, image 1 of 1
      • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
      Ask FixBot
    2. Besta Super 5000 Motherboard Replacement: step 8, image 1 of 1
      • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
      Ask FixBot
    3. Besta Super 5000 Motherboard Replacement: step 9, image 1 of 3 Besta Super 5000 Motherboard Replacement: step 9, image 2 of 3 Besta Super 5000 Motherboard Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
      • Potential for device damage: Do not yank or remove the ribbon from the device.
      • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
      Ask FixBot
    4. Besta Super 5000 Motherboard Replacement: step 10, image 1 of 2 Besta Super 5000 Motherboard Replacement: step 10, image 2 of 2
      • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
      • Carefully pry off the motherboard with an opening tool.
      Ask FixBot
    5. Besta Super 5000 Motherboard Replacement: step 11, image 1 of 1
      • Take the motherboard out of the body frame.
      Ask FixBot
    6. Besta Super 5000 Motherboard Replacement: step 12, image 1 of 2 Besta Super 5000 Motherboard Replacement: step 12, image 2 of 2
      • Lift the black keyboard mat off of the motherboard.
      • Replace the motherboard.
      Ask FixBot
2 other people completed this guide.
Jessie
373 Reputation
3 Guides authored
Ohio State, Team 1-5, Buehl Fall 2014 Member of Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 27
All Time: 711
