Up to 20% off select tools
Besta Super 5000 Back Cover Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
85
All Time:
877
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Besta Super 5000 Back Cover Replacement, Battery: step 1, image 1 of 1
      • Turn the device over so that the barcode is facing upwards.
      Ask FixBot
    2. Besta Super 5000 Back Cover Replacement: step 2, image 1 of 2 Besta Super 5000 Back Cover Replacement: step 2, image 2 of 2
      • Place your fingers on the battery cover arrow and pull the cover down and off the device.
      Ask FixBot
    3. Besta Super 5000 Back Cover Replacement: step 3, image 1 of 1
      • Pull upwards on the battery tab to remove the battery from the device.
      Ask FixBot
    1. Besta Super 5000 Back Cover Replacement, Back Cover: step 4, image 1 of 1
      • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
      Ask FixBot
    2. Besta Super 5000 Back Cover Replacement: step 5, image 1 of 1
      • Remove the two screws behind the battery using a Phillips #0 screwdriver.
      Ask FixBot
    3. Besta Super 5000 Back Cover Replacement: step 6, image 1 of 2 Besta Super 5000 Back Cover Replacement: step 6, image 2 of 2
      • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
      • Gently pry off the backing using an opening tool.
      Ask FixBot
Author
with
Jessie
373 Reputation
3 Guides authored
Ohio State, Team 1-5, Buehl Fall 2014 Member of Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 85
All Time: 877
