Up to 20% off select tools
Benchmade Griptillian Disassembly
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
109
All Time:
1,930
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 10 minutes
Difficulty: Very easy
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
How to disassemble your Benchmade Griptillian
    1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: step 1, image 1 of 1
      • Be sure to make note of what side the belt clip is on for reassembly.
      Ask FixBot
    2. Benchmade Griptillian Disassembly, Remove screws: step 2, image 1 of 1
      • Use a T6 bit to remove the two screws holding the belt clip.
      Ask FixBot
    3. Benchmade Griptillian Disassembly, Remove T6 Screws: step 3, image 1 of 1
      • Use the T6 bit to remove the four screws holding the handle in place.
      Ask FixBot
    4. Benchmade Griptillian Disassembly, Turn the knife over: step 4, image 1 of 1
      • Turn the knife over and remove one T6 screw.
      Ask FixBot
    5. Benchmade Griptillian Disassembly, Remove the T8 screw: step 5, image 1 of 1
      • Turn the knife over and remove the T8 screw that is going through the hinge.
      Ask FixBot
    6. Benchmade Griptillian Disassembly, Remove the handle: step 6, image 1 of 1
      • Once you've removed the screw, you can remove the handle.
      Ask FixBot
    7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: step 7, image 1 of 1
      • Using the T6 bit, drive the hinge pin out of the other handle.
      Ask FixBot
    8. Benchmade Griptillian Disassembly, Remove the other handle: step 8, image 1 of 1
      • Once you've done this you can remove the other handle.
      Ask FixBot
    9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: step 9, image 1 of 1
      • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
      Ask FixBot
    10. Benchmade Griptillian Disassembly, Sand both sides of copper: step 10, image 1 of 1
      • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
      Ask FixBot
    11. Benchmade Griptillian Disassembly, Reverse process to re assemble: step 11, image 1 of 1
      • Reverse process to re assemble.
      Ask FixBot
3 other people completed this guide.
Author
with
Spin Modder
256 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 109
All Time: 1,930
