Up to 20% off select tools
BenQ HT1075 Projector Lamp Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
7
Past 7 Days:
21
Past 30 Days:
113
All Time:
2,600
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
The projector's lamp is key to maintaining optimal image quality, and its periodic replacement is one of the most common tasks associated with owning a projector. All this replacement needs is a single screwdriver and about 5 minutes of your time.
    1. BenQ HT1075 Projector Lamp Replacement, Lamp: step 1, image 1 of 1
      • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
      • Fully remove the top cover in order to get to the lamp housing.
      Ask FixBot
    2. BenQ HT1075 Projector Lamp Replacement: step 2, image 1 of 1
      • Carefully peel off the adhesive film covering the lamp housing.
      Ask FixBot
    3. BenQ HT1075 Projector Lamp Replacement: step 3, image 1 of 1
      • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
      Ask FixBot
    4. BenQ HT1075 Projector Lamp Replacement: step 4, image 1 of 1
      • Remove the lamp from the projector by pulling on the lamp handle.
      • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
      Ask FixBot
4 other people completed this guide.
Author
with
Gabriela Remulla
1,026 Reputation
5 Guides authored
Cal Poly, Team S6-G1, Banghart Fall 2017 Member of Cal Poly, Team S6-G1, Banghart Fall 2017
CPSU-BANGHART-F17S6G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 113
All Time: 2,600
