Bella KitchenSmith 2 Slice Toaster 12082 Disassembly
    1. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly, Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 1, image 1 of 1
      • Remove the toaster's handle by firmly grasping it and pulling on it away from the device.
      • This may take a bit of effort - do not worry about pulling too hard - you will not break the toaster.
      Ask FixBot
    2. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Turn the toaster over. Remove the two rubber gaskets from the legs of the toaster using a pointed tool such as tweezers.
      Ask FixBot
    3. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 3, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 3, image 2 of 2
      • Using the Triangle #2 screwdriver, remove four 100.0 mm screws from the base of the toaster.
      Ask FixBot
    4. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 4, image 1 of 1
      • Lift off the plastic cover.
      • You may feel a little resistance from the connection between the control knob and its counterpart on the circuit panel but just wiggle the cover around a bit and pull up and the cover should come off.
      Ask FixBot
    5. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 5, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 5, image 2 of 2
      • Unfold the four tabs that hold on the top cover to the toaster
      • In the next few steps you will be unfolding a lot of the metal tabs - you can either use your hand or the metal spudger to do so
      • Many of the metal tabs are very fragile - be very careful when you unfold them or they will break!
      Ask FixBot
    6. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 6, image 1 of 1
      • Unfold the tab above the toaster's handle.
      Ask FixBot
    7. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 7, image 1 of 1
      • Pull the metal rod that was under the tab up and away from the device.
      • You may feel a bit of resistance as you pull the rod up - just wiggle it around a bit as you pull up and the rod should come free.
      Ask FixBot
    8. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 8, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 8, image 2 of 2
      • Remove the spring from the front of the toaster.
      Ask FixBot
    9. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 9, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 9, image 2 of 2
      • Unfold the two tabs on the back of the toaster.
      Ask FixBot
    10. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 10, image 1 of 1
      • Remove the bread holder base from the toaster by lifting it up and then pulling it towards you.
      Ask FixBot
    11. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 11, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 11, image 2 of 2
      • Remove the spring part of the bread holding mechanism.
      Ask FixBot
    12. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 12, image 1 of 1
      • Unfold the two tabs on the top of the toaster that hold the central bar in place.
      Ask FixBot
    13. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 13, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 13, image 2 of 2
      • Remove the central bar.
      Ask FixBot
    14. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 14, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 14, image 2 of 2
      • Undo the latch to the breadcrumb tray and swing the tray open.
      Ask FixBot
    15. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 15, image 1 of 1
      • Unfold the two tabs that hold the breadcrumb tray in place.
      Ask FixBot
    16. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 16, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 16, image 2 of 2
      • Lay the tray back down to its resting position and then pull the tray up and away from the device.
      Ask FixBot
    17. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 17, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 17, image 2 of 2
      • Unfold the twelve tabs that hold both sides of the toaster in place.
      Ask FixBot
    18. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 18, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 18, image 2 of 2
      • Pull the bottom of the side panels out and over the inner toaster pieces that are holding them in place.
      • Then completely remove both side panels.
      Ask FixBot
    19. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 19, image 1 of 2 Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 19, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the two 8.0 mm screws from the backside of the toaster.
      Ask FixBot
    20. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 20, image 1 of 1
      • Undo the two tabs on the backside of the toaster.
      Ask FixBot
    21. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 21, image 1 of 1
      • Slightly pull the back panel of the toaster away from the device.
      • Do not try to attempt to completely remove the back panel - there are wires attached to the back panel that are still attached to the main body of the toaster - any attempt to completely remove the back panel could result in breaking your toaster!
      Ask FixBot
    22. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 22, image 1 of 1
      • Remove the bread holders from the device.
      • When you pull back the back panel, the bread holders will fall out.
      • The bread holders were positioned so that their tips were pointed out towards the edges of the toaster slots.
      Ask FixBot
    23. Bella KitchenSmith 2 Slice Toaster 12082 Disassembly: step 23, image 1 of 1
      • Once you've taken the toaster apart you can get a very good sense of how it operates. Here's the basics of how it works:
      • There is always power running to the toaster when it is plugged in but the electrical circuit is broken until the handle is pressed down. When the handle is pressed down, two switches are closed, closing the circuit and turning on the power to the toaster.
      • When the power goes on, an electromagnet in the circuit board is turned on, causing a magnet on the toasters handle to bond to the electromagnet and holding the handle down (and keeping the toaster on) until the circuit is broken.
      • The circuit is broken when a predetermined amount of power has entered the 555 timer chip in the circuit board - when enough power has entered the chip it sends a signal that causes the electromagnet to lose enough of its magnetic field that the handle is released and the bread pops.
      • The amount of power that flows to the chip is controlled by a potentiometer which is connected to the circular control knob.
      • If the maximum toasting setting of seven is used, the potentiometer only allows a small amount of the power to flow into the chip, causing it to take longer to reach the required threshold of power and making the bread spend a longer time in the toaster.
      • On the other hand, if the cancel setting is used, the potentiometer barely offers any resistance at all, allowing the power threshold in the chip to quickly be reached and as a result, rapidly triggering the popping of the toaster.
      Ask FixBot
3 other people completed this guide.
3 Guide Comments
Any ideas or suggestions for fixing the handle not strong down in this toaster? The handle goes down & toaster cooks, but the handle doesn’t stay down & pops back up without staying.
Nick - Reply Share
@nick11338 same issue here!
Paloma Soledad - Reply Share
@palomasoledad Hey bro, you should check out my quick YouTube shorts video where I show that I made a temporary fix to the Toaster Latch. Just a quick workaround, it would be better to for me or someone to fully figure it out at some point. But I figure there are more important or financial things to do for now, and the rubber band and method are a good, quick Fix.
https://www.youtube.com/shorts/7pTVDo7DQ...
Nick - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 107
All Time: 2,896
