Bella 4-Slice Toaster Oven Temperature Dial Replacement
    1. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Outer Shell: step 1, image 1 of 1
      • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
      Ask FixBot
    2. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 2, image 1 of 1
      • Open the front glass door of the toaster oven.
      Ask FixBot
    3. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 3, image 1 of 1
      • Locate retaining screw on the upper-middle portion of the door frame.
      Ask FixBot
    4. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 4, image 1 of 1
      • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
      Ask FixBot
    5. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 5, image 1 of 1
      • Flip toaster onto back panel with feet facing forward.
      Ask FixBot
    6. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 6, image 1 of 1
      • Use spudger to pry the grey rubber inserts from the black plastic feet.
      Ask FixBot
    7. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 7, image 1 of 1
      • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
      Ask FixBot
    8. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 8, image 1 of 1
      • Lift the black outer cover off of the toaster
      Ask FixBot
    1. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Temperature Dial: step 9, image 1 of 1
      • Using a plastic spudger, gently pry the black plastic temperature dial away from the face of the toaster.
      Ask FixBot
    2. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 10, image 1 of 1
      • Remove two 5.91 mm #2 Phillips screws which secure the inner component to the toaster.
      Ask FixBot
    3. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 11, image 1 of 1
      • Inside the device, unplug the red wire connecting the black plastic part of the dial to the heating element.
      Ask FixBot
    4. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 12, image 1 of 1
      • Now unplug the other red wire from the black plastic part of the dial.
      Ask FixBot
    5. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 13, image 1 of 1
      • Unplug the two white wires from the metal part of the dial.
      Ask FixBot
    6. Bella 4-Slice Toaster Oven Temperature Dial Replacement: step 14, image 1 of 1
      • Remove the dial from device interior.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 764
