Bell and Howell DNV16HDZ LED Replacement
    1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: step 1, image 1 of 2 Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: step 1, image 2 of 2
      • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
      Ask FixBot
    2. Bell and Howell DNV16HDZ LED Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
      • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
      Ask FixBot
    3. Bell and Howell DNV16HDZ LED Replacement: step 3, image 1 of 1
      • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
      Ask FixBot
    1. Bell and Howell DNV16HDZ LED Replacement, LED: step 4, image 1 of 1
      • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
      Ask FixBot
    2. Bell and Howell DNV16HDZ LED Replacement: step 5, image 1 of 3 Bell and Howell DNV16HDZ LED Replacement: step 5, image 2 of 3 Bell and Howell DNV16HDZ LED Replacement: step 5, image 3 of 3
      • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
      • From here we can pop out the LED using the wedge or your fingers if you can manage it.
      Ask FixBot
Donald Desrosier
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 669
