Belkin F5L114 Battery Replacement
  1. Belkin F5L114 Battery Replacement, Battery: step 1, image 1 of 3 Belkin F5L114 Battery Replacement, Battery: step 1, image 2 of 3 Belkin F5L114 Battery Replacement, Battery: step 1, image 3 of 3
    • Switch the power button that is located at the bottom left of the keyboard to Off.
    Ask FixBot
  2. Belkin F5L114 Battery Replacement: step 2, image 1 of 2 Belkin F5L114 Battery Replacement: step 2, image 2 of 2
    • Flip the keyboard over.
    Ask FixBot
  3. Belkin F5L114 Battery Replacement: step 3, image 1 of 3 Belkin F5L114 Battery Replacement: step 3, image 2 of 3 Belkin F5L114 Battery Replacement: step 3, image 3 of 3
    • Pull back gently on the left side of the bottom-left rubber foot enough to expose the small screw.
    Ask FixBot
  4. Belkin F5L114 Battery Replacement: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to unscrew the screw.
    • The screw may not come fully out of the device.
    Ask FixBot
  5. Belkin F5L114 Battery Replacement: step 5, image 1 of 1
    • Pull back gently on the bottom left corner of the middle rubber foot enough to expose the small screw.
    Ask FixBot
  6. Belkin F5L114 Battery Replacement: step 6, image 1 of 1
    Ask FixBot
  7. Belkin F5L114 Battery Replacement: step 7, image 1 of 2 Belkin F5L114 Battery Replacement: step 7, image 2 of 2
    • Pull back gently on the right side of the bottom-right rubber enough to expose the small screw.
    Ask FixBot
  8. Belkin F5L114 Battery Replacement: step 8, image 1 of 1
    Ask FixBot
  9. Belkin F5L114 Battery Replacement: step 9, image 1 of 2 Belkin F5L114 Battery Replacement: step 9, image 2 of 2
    • Insert the spudger into the space next to the right screw area.
    • Gently pry open the battery case.
    Ask FixBot
  10. Belkin F5L114 Battery Replacement: step 10, image 1 of 3 Belkin F5L114 Battery Replacement: step 10, image 2 of 3 Belkin F5L114 Battery Replacement: step 10, image 3 of 3
    • Gently pry the battery cover off.
    Ask FixBot
  11. Belkin F5L114 Battery Replacement: step 11, image 1 of 2 Belkin F5L114 Battery Replacement: step 11, image 2 of 2
    • Remove the battery cover.
    • Locate the battery.
    Ask FixBot
  12. Belkin F5L114 Battery Replacement: step 12, image 1 of 2 Belkin F5L114 Battery Replacement: step 12, image 2 of 2
    • Lift the battery up using the spudger.
    • The battery is taped down.
    Ask FixBot
  13. Belkin F5L114 Battery Replacement: step 13, image 1 of 3 Belkin F5L114 Battery Replacement: step 13, image 2 of 3 Belkin F5L114 Battery Replacement: step 13, image 3 of 3
    Tool used on this step:
    Buy
    • Gently unplug the battery from the motherboard using the tweezers.
    • Remove the battery.
    Ask FixBot
4 Guide Comments
Hi, I would like buy another battery for my keyboard. May you help me please?
Rundy Henry - Reply Share
I’m not 100% sure but I think you can find them on Amazon.
Michelle Bianco - Reply Share
Where can I buy a new battery?
Kingstonite - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 79
All Time: 2,394
