Beko DHR73431W Capacitor Replacement
  1. Beko DHR73431W Capacitor Replacement, Capacitor: step 1, image 1 of 1
    • Remove the two Phillips 02 (cross-head) screws securing the lid
    • Capacitors store dangerous levels of electrical current, they must be discharged before handling. To begin UNPLUG the device from the mains, and let it sit for a few hours Make sure you let the power drain before opening BEWARE: it is possible for capacitors to store a life-threatening charge for months or years.
    • Before commencing work inside or attempting to handle the capacitor, very cautiously short the terminals to ground and dissipate any residual charge.
    Ask FixBot
  2. Beko DHR73431W Capacitor Replacement: step 2, image 1 of 3 Beko DHR73431W Capacitor Replacement: step 2, image 2 of 3 Beko DHR73431W Capacitor Replacement: step 2, image 3 of 3
    • Unscrew and remove the five Phillips 02 cross-head screws of the side panel
    • Remove the single Phillips 02 cross-head screw on the bottom
    • Remove the two Phillips 21 cross-head screws from the top
    Ask FixBot
  3. Beko DHR73431W Capacitor Replacement: step 3, image 1 of 3 Beko DHR73431W Capacitor Replacement: step 3, image 2 of 3 Beko DHR73431W Capacitor Replacement: step 3, image 3 of 3
    • WARNING! Discharge any residual current from the capacitor before continuing.
    • Remove the single Phillips 02 cross-head screw for the capacitor labeled with a large '8'.
    • Unplug the two connectors at the base of the capacitor
    Ask FixBot
To continue, put in your new capacitor then follow the steps in reverse.
Daniel Grey
162 Reputation
1 Guide authored
2 Guide Comments
very helpful. Many thanks
Muhammad Masood HUSSAIN - Reply Share
No worries, thank you
Daniel Grey - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 55
All Time: 2,695
