Introduction
The I/O and processing board of the P16-M has the audio processing components, audio jacks, and other connectors mounted on it. You might need to take it out to replace broken connectors.
Remove 10 Phillips #2 screws from around the edges of the bottom plate
Use a spudger or flathead screwdriver to lever the bottom plate free.
Remove the two silver Phillips #2 screws from the back plate.
With the P16-M face down on the table, ease the circuit board away from the back plate to free the connectors from their slots, then manoeuvre it out of the case.
Push on the plastic tabs either side of the ribbon connector to free the ribbon.
Pull on the ribbon cable to remove it. This should barely require any force.
