Beboncool Nintendo Switch Gamepad Disassembly
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
70
All Time:
1,735
Comments: 3
3 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide details the process of disassembling the Beboncool Gamepad for Nintendo Switch. This guide serves as the starting point for disassembly in the event that more extensive troubleshooting must be performed or as the starting procedures to replace an internal component.
Tools
    1. Beboncool Nintendo Switch Gamepad Disassembly, Beboncool Nintendo Switch Gamepad Disassembly: step 1, image 1 of 3 Beboncool Nintendo Switch Gamepad Disassembly, Beboncool Nintendo Switch Gamepad Disassembly: step 1, image 2 of 3 Beboncool Nintendo Switch Gamepad Disassembly, Beboncool Nintendo Switch Gamepad Disassembly: step 1, image 3 of 3
      • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
      Ask FixBot
    2. Beboncool Nintendo Switch Gamepad Disassembly: step 2, image 1 of 2 Beboncool Nintendo Switch Gamepad Disassembly: step 2, image 2 of 2
      • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
      Ask FixBot
    3. Beboncool Nintendo Switch Gamepad Disassembly: step 3, image 1 of 3 Beboncool Nintendo Switch Gamepad Disassembly: step 3, image 2 of 3 Beboncool Nintendo Switch Gamepad Disassembly: step 3, image 3 of 3
      • Gently separate the two halves of the controller.
      • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
      • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
      Ask FixBot
    4. Beboncool Nintendo Switch Gamepad Disassembly: step 4, image 1 of 2 Beboncool Nintendo Switch Gamepad Disassembly: step 4, image 2 of 2
      • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
      Ask FixBot
    5. Beboncool Nintendo Switch Gamepad Disassembly: step 5, image 1 of 3 Beboncool Nintendo Switch Gamepad Disassembly: step 5, image 2 of 3 Beboncool Nintendo Switch Gamepad Disassembly: step 5, image 3 of 3
      • Lift the motherboard from the back case with the vibration motors and button boards attached.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 70
All Time: 1,735
