Up to 20% off select tools
Beats Studio3 Wireless Left Driver Assembly Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
32
Past 30 Days:
154
All Time:
3,473
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the speaker on your Beats Studio3 Wireless headphones.
The speaker allows users to receive audio through the headphone, and one can hear what they are playing through their phone or other devices. Failing audio is the most common indicator of faulty speakers. You may experience no sound coming from the speakers and/or poor quality, which indicates a replacement for the speaker.
    1. Beats Studio3 Wireless Left Driver Assembly Replacement, Ear Pad: step 1, image 1 of 2 Beats Studio3 Wireless Left Driver Assembly Replacement, Ear Pad: step 1, image 2 of 2
      • Find the separation between the headset and ear cushion.
      • Use an opening tool to go underneath the separation site and split the pieces apart.
      Ask FixBot
    2. Beats Studio3 Wireless Left Driver Assembly Replacement: step 2, image 1 of 3 Beats Studio3 Wireless Left Driver Assembly Replacement: step 2, image 2 of 3 Beats Studio3 Wireless Left Driver Assembly Replacement: step 2, image 3 of 3
      • You can also use your hands to remove it completely.
      • Pulling it off can be challenging; make sure to apply enough pressure.
      Ask FixBot
    1. Beats Studio3 Wireless Left Driver Assembly Replacement, Left Driver Assembly: step 3, image 1 of 2 Beats Studio3 Wireless Left Driver Assembly Replacement, Left Driver Assembly: step 3, image 2 of 2
      • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
      • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
      • Open the speaker by pulling the top layer of the speaker.
      Ask FixBot
    2. Beats Studio3 Wireless Left Driver Assembly Replacement: step 4, image 1 of 3 Beats Studio3 Wireless Left Driver Assembly Replacement: step 4, image 2 of 3 Beats Studio3 Wireless Left Driver Assembly Replacement: step 4, image 3 of 3
      • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
      • Use a nylon spudger to remove the glue.
      • Pull on the wire to remove it while also removing the blue rubber band.
      Ask FixBot
    3. Beats Studio3 Wireless Left Driver Assembly Replacement: step 5, image 1 of 3 Beats Studio3 Wireless Left Driver Assembly Replacement: step 5, image 2 of 3 Beats Studio3 Wireless Left Driver Assembly Replacement: step 5, image 3 of 3
      • Using a soldering iron to remove the cables on the charger port.
      • For help with soldering, check out the How to Solder and Desolder Connections guide.
      • Remove the two wires connected in the middle of the speaker using a soldering iron.
      • Remove the speaker from the headset.
      Ask FixBot
Author
with
Nayeli watts
548 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 154
All Time: 3,473
