Up to 20% off select tools
Beats Studio3 Wireless Battery Replacement
Views: 14K
View statistics:
Past 24 Hours:
16
Past 7 Days:
102
Past 30 Days:
504
All Time:
14,270
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your Beats Studio3 Wireless headphones (model number: A1914).
The battery helps the Beats Studio3 Wireless headphones to power on. It's designed for long battery life of up to 22 hours for all-day. A failed battery will cause your Beats Studio3 Wireless to not turn on. You can take a look at the bottom right ear pad to check if the five lights are on. In some cases, your Beats Studio3 Wireless will have faulty charging due to a deteriorated battery.
    1. Beats Studio3 Wireless Battery Replacement, Battery: step 1, image 1 of 2 Beats Studio3 Wireless Battery Replacement, Battery: step 1, image 2 of 2
      • Use a pointed nylon spudger to remove the center circular panel on the right side of your device.
      • Be gentle while removing this piece as it is glued on with adhesive.
      Ask FixBot
    2. Beats Studio3 Wireless Battery Replacement: step 2, image 1 of 2 Beats Studio3 Wireless Battery Replacement: step 2, image 2 of 2
      • Remove the four 3.5 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    3. Beats Studio3 Wireless Battery Replacement: step 3, image 1 of 3 Beats Studio3 Wireless Battery Replacement: step 3, image 2 of 3 Beats Studio3 Wireless Battery Replacement: step 3, image 3 of 3
      • Using a pointed nylon spudger, remove the tab located on the inner part of the headband labeled "R."
      • Place the nylon spudger in between the side panels and push inward going from bottom to top to separate both sides of the panel.
      • The panel will pop open after separating.
      Ask FixBot
    4. Beats Studio3 Wireless Battery Replacement: step 4, image 1 of 1
      • Place the nylon spudger underneath the battery, push inward and separate the battery from the inside.
      • Never use sharp tools to pry batteries. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
      Ask FixBot
    5. Beats Studio3 Wireless Battery Replacement: step 5, image 1 of 2 Beats Studio3 Wireless Battery Replacement: step 5, image 2 of 2
      • Use a nylon spudger to lift up the glue sticking the wires down.
      • Use a nylon spudger to lift the connector to disconnect the battery.
      Ask FixBot
7 other people completed this guide.
Author
with
Lourdes Dejesus
243 Reputation
1 Guide authored
4 Guide Comments
Should the glue be reapplied or is it okay to simply place back on?
Jake Allen - Reply Share
the replacement batteries usually come with a gluepad on the back.
The connector its up to you - you risk the chance of the connector coming lose and u have to reopen the headset. But ill take the chance for now, lets see how it holds up without new glue.
seb - Reply Share
Tengo una duda mis audífonos la batería esta full de voltaje pero me marca un rojo y no me prenden q podría ser o que solución podría darle
luis m cruz - Reply Share
My beats studio 3 proplem was it plink whit when i connect it with the charger, but when i press to start it it blinks full red .
My Qus is .. is the battery are dameged ..?!
Hmam - Reply Share
Past 24 Hours: 16
Past 7 Days: 102
Past 30 Days: 504
All Time: 14,270
