Up to 20% off select tools
Beats Studio3 Micro USB-B Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
145
All Time:
2,908
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
Hey headphone enthusiasts! Ever faced that frustrating moment when your Beats Studio3 won't charge properly? Don't worry, I've got a quick fix for you. In this guide, I'll walk you through a simple repair for the common issue of a faulty charging port. All you'll need are some basic tools, a replacement part if necessary, and about 30 minutes of your time. It's a hassle-free process that's a lifesaver for those unexpected charging glitches that can happen over time. Stick with me, and we'll have your favorite headphones back to full power in no time!"
    1. Beats Studio3 Micro USB-B Replacement, Micro USB-B: step 1, image 1 of 3 Beats Studio3 Micro USB-B Replacement, Micro USB-B: step 1, image 2 of 3 Beats Studio3 Micro USB-B Replacement, Micro USB-B: step 1, image 3 of 3
      • Remove the pad that is on the charging port side using an opening tool.
      Ask FixBot
    2. Beats Studio3 Micro USB-B Replacement: step 2, image 1 of 3 Beats Studio3 Micro USB-B Replacement: step 2, image 2 of 3 Beats Studio3 Micro USB-B Replacement: step 2, image 3 of 3
      • Remove seven screws from the earpiece using a Phillips screwdriver.
      • Pry the top panel away from the rest of the speaker using an opening tool.
      • There will still be wires attached, so be gentle.
      Ask FixBot
    3. Beats Studio3 Micro USB-B Replacement: step 3, image 1 of 3 Beats Studio3 Micro USB-B Replacement: step 3, image 2 of 3 Beats Studio3 Micro USB-B Replacement: step 3, image 3 of 3
      • Use the soldering iron to carefully desolder five different wires from their respective points.
      • After disconnecting the wires, gently push the charger upward using your fingers to detach it from the base. Be careful to avoid damaging any components
      • Position the new charger by aligning it properly with the base. Push the new charger into place, ensuring it fits snugly and securely.
      • Reattach the five wires to their designated points on the new charger by soldering them securely. Ensure each wire is correctly connected to its corresponding point to guarantee proper functionality.
      Ask FixBot
2 other people completed this guide.
Author
with
Jael Estrada-Cervantes
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 145
All Time: 2,908
