Beats Studio First Generation Ear Cushion Replacement
    1. Beats Studio First Generation Ear Cushion Replacement, Removing the ear cushion.: step 1, image 1 of 3 Beats Studio First Generation Ear Cushion Replacement, Removing the ear cushion.: step 1, image 2 of 3 Beats Studio First Generation Ear Cushion Replacement, Removing the ear cushion.: step 1, image 3 of 3
      • Pinch the ear cushion between your thumb and forefinger.
      • Be very careful when pulling off the ear cushion, as the material holding the cushion onto the plastic ring can rip easily.
      • Carefully pull the cushion directly away from the earpiece.
      • The cushion will have a thin piece of foam inside of it that may fall out upon removal. Make sure to save this for reassembly.
      • Repeat for the other ear cushion.
      Ask FixBot
    2. Beats Studio First Generation Ear Cushion Replacement, Removing the plastic ring.: step 2, image 1 of 3 Beats Studio First Generation Ear Cushion Replacement, Removing the plastic ring.: step 2, image 2 of 3 Beats Studio First Generation Ear Cushion Replacement, Removing the plastic ring.: step 2, image 3 of 3
      • Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
      • Congratulations, you now have access to the rest of the speaker!
      • For reassembly, the black ring cannot snap back into the speaker the way it was disassembled. It must first go inside the black lip of the ear cushion. The black lip is located on the back side of the ear cushion. Please refer to the last two pictures on this step.
      • The black lip is located on the back side of the ear cushion.
      Ask FixBot
Finish Line
15 other people completed this guide.
Anand Mangal
1,101 Reputation
2 Guides authored
Cal Poly, Team 9-18, Regan Spring 2014 Member of Cal Poly, Team 9-18, Regan Spring 2014
CPSU-REGAN-S14S9G18
4 Members
72 Guides authored
4 Guide Comments
De nada me sirve saber cómo colocarlos si no sé donde conseguirlos... Ese debería ser el paso 1 del instructivo...
IGNACIO GREIFFENSTEIN - Reply Share
What if I break the black ring where do I get a replacement
Chris h - Reply Share
Hi - do you know where i can buy the replacement ear cushions for these particular headphones?
Jade ijeh - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 111
All Time: 64,867
