Beats Studio 2 Wireless Speaker Replacement
  1. Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: step 1, image 1 of 2 Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: step 1, image 2 of 2
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
    Ask FixBot
  2. Beats Studio 2 Wireless Speaker Replacement: step 2, image 1 of 3 Beats Studio 2 Wireless Speaker Replacement: step 2, image 2 of 3 Beats Studio 2 Wireless Speaker Replacement: step 2, image 3 of 3
    • Pull the rest of the cushion away from the adhesive with your hands.
    Ask FixBot
  3. Beats Studio 2 Wireless Speaker Replacement, Speaker: step 3, image 1 of 2 Beats Studio 2 Wireless Speaker Replacement, Speaker: step 3, image 2 of 2
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
    Ask FixBot
  4. Beats Studio 2 Wireless Speaker Replacement: step 4, image 1 of 1
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
    Ask FixBot
  5. Beats Studio 2 Wireless Speaker Replacement: step 5, image 1 of 2 Beats Studio 2 Wireless Speaker Replacement: step 5, image 2 of 2
    • Gently pull the wire with rubber connectors off of the speaker.
    Ask FixBot
  6. Beats Studio 2 Wireless Speaker Replacement: step 6, image 1 of 1
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
    Ask FixBot
After soldering the new speaker, reassemble your device by following the steps in reverse order.
4 other people completed this guide.
Mike Rosiello
325 Reputation
2 Guides authored
1 Guide Comment
I didn't need to replace a speaker but just touch up the solder joints, this was a great guide! Thank you!
William Pryor - Reply Share
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 47
All Time: 1,083
