Beats Solo Speaker Driver Replacement
  1. Beats Solo Speaker Driver Replacement, Speaker Driver: step 1, image 1 of 2 Beats Solo Speaker Driver Replacement, Speaker Driver: step 1, image 2 of 2
    • Hold the ear cup securely with one hand.
    • With the other hand, turn the speaker cushion counter-clockwise while gently pulling it upwards.
    • This detaches the cushion from the locking tabs.
    • Do not apply too much pressure, as bending the tabs could cause them to crack.
    Ask FixBot
  2. Beats Solo Speaker Driver Replacement: step 2, image 1 of 1
    • Remove five 3 mm screws from the speaker cover using a Phillips #0 screwdriver.
    • Carefully lift the red speaker cover, exposing the speaker driver and speaker wires.
    Ask FixBot
  3. Beats Solo Speaker Driver Replacement: step 3, image 1 of 1
    • Use the soldering iron to warm up each of the solder joints and gently remove the three wires connected to the speaker driver.
    • Wait for the solder to soften before removing the wires so as not to damage the copper wires.
    • Remove the old speaker and align the new speaker in the same direction.
    • Connect each wire to the originally intended solder spot. Dab a small amount of new solder to hold each wire in place. Verify the wire sequence is also correct to avoid audio problems.
    • Make sure to not mix the cables up when soldering as the wires have to go back in the exact same location.
    Ask FixBot
Victor Uriarte
406 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 54
All Time: 371
