Beats Solo Auxiliary Port Replacement
  1. Beats Solo Auxiliary Port Replacement, Auxiliary Port: step 1, image 1 of 2 Beats Solo Auxiliary Port Replacement, Auxiliary Port: step 1, image 2 of 2
    • Hold the ear cup securely with one hand.
    • With the other hand, turn the speaker cushion counter-clockwise while gently pulling it upwards.
    • This detaches the cushion from the locking tabs.
    • Do not apply too much pressure, as bending the tabs could cause them to crack.
    Ask FixBot
  2. Beats Solo Auxiliary Port Replacement: step 2, image 1 of 1
    • Remove five 3 mm screws from the speaker cover using a Phillips #0 screwdriver.
    • Carefully lift the red speaker cover, exposing the speaker driver and speaker wires.
    Ask FixBot
  3. Beats Solo Auxiliary Port Replacement: step 3, image 1 of 1
    • Use a soldering iron, melt each solder joint and remove the four wires soldered to the auxiliary port.
    • Do not pull on the wires until the solder has softened, as this can damage the copper strands.
    • Remove the old AUX port and place the new port facing in the same direction.
    • Connect the wires to the preexisting solder locations. When completed, add a small amount of new solder to hold the wires in place. Check if the wiring is correct to ensure the audio is working properly.
    • Make sure to to not mix the cables up when soldering as the wires have to go back in the exact same location.
    Ask FixBot
Victor Uriarte
406 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 34
All Time: 257
