Beats Solo 3 Charging Port Replacement
  1. Beats Solo 3 Charging Port Replacement, Charging Port: step 1, image 1 of 1
    • Use a nylon or metal spudger to carefully remove the ear pad from the right ear cup.
    • Be careful to not rip the ear pad fabric with your tools.
    Ask FixBot
  2. Beats Solo 3 Charging Port Replacement: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the seven screws that hold the speaker in place.
    • There are two screws in the big red circle at the bottom.
    Ask FixBot
  3. Beats Solo 3 Charging Port Replacement: step 3, image 1 of 1
    • Desolder all wires connecting the circuit panel to the rest of the device.
    • There are two wires in the big red circle at the bottom and one in the small red circle above.
    Ask FixBot
  4. Beats Solo 3 Charging Port Replacement: step 4, image 1 of 2 Beats Solo 3 Charging Port Replacement: step 4, image 2 of 2
    • After you desolder all wires you are able to remove and replace the charging port.
    Ask FixBot
3 other people completed this guide.
1 Guide Comment
tengo una duda en este puedo areglar el boton de encendido del bluetooth?
Gabriel Dayahirt Garcia - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 199
All Time: 7,879
