Beats Solo 3 Battery Replacement
    1. Beats Solo 3 Battery Replacement, Battery: step 1, image 1 of 2 Beats Solo 3 Battery Replacement, Battery: step 1, image 2 of 2
      • Pry off the outside pane on the right side of the headphone with an opening tool.
      Ask FixBot
    2. Beats Solo 3 Battery Replacement: step 2, image 1 of 1
      • You should see your battery here. It will be square with yellow packaging.
      • Be sure not to pull on the wires that are connected to the outside panel. This may cause damage to your headphones.
      Ask FixBot
    3. Beats Solo 3 Battery Replacement: step 3, image 1 of 2 Beats Solo 3 Battery Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Grasp the battery's small bundled connector, and pull gently to remove.
      • Carefully remove the top attachment from the headphones with tweezers or your fingers.
      Ask FixBot
    4. Beats Solo 3 Battery Replacement: step 4, image 1 of 2 Beats Solo 3 Battery Replacement: step 4, image 2 of 2
      • Use an opening tool or a nylon spudger to carefully remove the battery. Make sure you pry upward.
      • Do not bend or puncture the lithium-ion battery.
      • Once that is removed, make sure you peel off the sticker where the battery is placed if it stuck to the battery.
      • If it is, then place it back where it belongs in the headphones.
      Ask FixBot
6 other people completed this guide.
8 Guide Comments
Where too buy battery?
GSD - Reply Share
Google . Internet
Mari Carmen Núñez - Reply Share
Thank you! This worked great!
NYCGinkgo - Reply Share
Hello I have an issue where the battery is soldered on and only has two wires can anyone advise. My headphones are beats solo3
agustin rodiles - Reply Share
same issue too
ethan b - Reply Share
Past 24 Hours: 10
Past 7 Days: 118
Past 30 Days: 540
All Time: 26,094
