Beats Solo 2 Wireless Earpads Replacement
  1. Beats Solo 2 Wireless Earpads Replacement, Earpads: step 1, image 1 of 3 Beats Solo 2 Wireless Earpads Replacement, Earpads: step 1, image 2 of 3 Beats Solo 2 Wireless Earpads Replacement, Earpads: step 1, image 3 of 3
    • Set the headphones down on a flat surface.
    • Insert a plastic card or opening pick between between the earpads and the speaker housing.
    • Carefully pry around the entire perimeter of the the pads until they fully release.
    Ask FixBot
  2. Beats Solo 2 Wireless Earpads Replacement: step 2, image 1 of 1
    • Use the card to clean up the adhesive residue left on the headphones.
    • Apply high-concentration isopropyl alcohol to a cloth and use it to remove any lingering adhesive.
    Ask FixBot
  3. Beats Solo 2 Wireless Earpads Replacement: step 3, image 1 of 1
    • Fold the other side of the headphones you are not working on.
    • This makes it easier to work and focus on the side you are on.
    • Carefully pick up the new pads and line them up with the Beats.
    • The new earpads come with the adhesive on them already; you just have to peel the plastic covering off.
    Ask FixBot
  4. Beats Solo 2 Wireless Earpads Replacement: step 4, image 1 of 1
    • Press down on the new pad to make sure it adheres to the headphones.
    • Make sure to go around the pad and press down on every part.
    Ask FixBot
  5. Beats Solo 2 Wireless Earpads Replacement: step 5, image 1 of 1
    • Find a large object and place the headphones on it just like the object is wearing the headphones.
    • Leave the headphones on the object for an hour so it can clamp the earpads to itself.
    • After 1 hour, you are good to go.
    Ask FixBot
Finish Line
Ayotunde Dada
291 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 68
All Time: 1,352
