Beats Solo 2 Wireless Battery Replacement
  1. Beats Solo 2 Wireless Battery Replacement, Battery: step 1, image 1 of 3 Beats Solo 2 Wireless Battery Replacement, Battery: step 1, image 2 of 3 Beats Solo 2 Wireless Battery Replacement, Battery: step 1, image 3 of 3
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
    Ask FixBot
  2. Beats Solo 2 Wireless Battery Replacement: step 2, image 1 of 3 Beats Solo 2 Wireless Battery Replacement: step 2, image 2 of 3 Beats Solo 2 Wireless Battery Replacement: step 2, image 3 of 3
    • Remove the right outer speaker casing.
    Ask FixBot
  3. Beats Solo 2 Wireless Battery Replacement: step 3, image 1 of 3 Beats Solo 2 Wireless Battery Replacement: step 3, image 2 of 3 Beats Solo 2 Wireless Battery Replacement: step 3, image 3 of 3
    • Use tweezers to disconnect the battery connector from the circuit board.
    • Do not pull on the wires.
    Ask FixBot
  4. Beats Solo 2 Wireless Battery Replacement: step 4, image 1 of 3 Beats Solo 2 Wireless Battery Replacement: step 4, image 2 of 3 Beats Solo 2 Wireless Battery Replacement: step 4, image 3 of 3
    • Use an opening pick to gently pry up the battery.
    • The battery is secured in the housing with adhesive. You can apply some high-concentration alcohol beneath the battery to help loosen the adhesive.
    • Avoid bending or puncturing the battery.
    Ask FixBot
  5. Beats Solo 2 Wireless Battery Replacement: step 5, image 1 of 1
    • Lift the battery up and out of the chassis.
    Ask FixBot
Cooper Truong
280 Reputation
2 Guides authored
IUPUI, Team 2-1, Harley Spring 2024 Member of IUPUI, Team 2-1, Harley Spring 2024
IUPUI-HARLEY-S24S2G1
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 64
All Time: 1,688
