Beats Pill 2024 Motherboard Replacement
  1. Beats Pill 2024 Motherboard Replacement, Subwoofer: step 1, image 1 of 1
    • Remove the strap.
  2. Beats Pill 2024 Motherboard Replacement: step 2, image 1 of 2 Beats Pill 2024 Motherboard Replacement: step 2, image 2 of 2
    • With the Beats Pill sitting on a flat surface, insert a spudger into the seam between the chassis and grille.
    • Slide the spudger around the entire perimeter of the grille to sever the adhesive securing the grille.
    • Reapply adhesive when reinstalling the grille.
    • Remove the grille.
  3. Beats Pill 2024 Motherboard Replacement: step 3, image 1 of 2 Beats Pill 2024 Motherboard Replacement: step 3, image 2 of 2
    • Use a spudger to remove the six stickers on the face of the driver assembly.
    • Place the stickers on a clean surface so as not to ruin the adhesive.
  4. Beats Pill 2024 Motherboard Replacement: step 4, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the six 14.3 mm screws that secure the driver assembly and speaker body together.
  5. Beats Pill 2024 Motherboard Replacement: step 5, image 1 of 2 Beats Pill 2024 Motherboard Replacement: step 5, image 2 of 2
    • Insert a spudger into the seam between the driver assembly and speaker body.
    • Gently slide the spudger around the perimeter while prying to separate the driver assembly from the speaker body.
    • This should not require much force.
  6. Beats Pill 2024 Motherboard Replacement: step 6, image 1 of 1
    • Disconnect the two subwoofer connections from their motherboard sockets.
    • Depress the clip on each connector prior to removal.
    • Use tape or a marker to mark where each connector goes.
    • If you're completing a tweeter replacement, skip to Step 8.
  7. Beats Pill 2024 Motherboard Replacement: step 7, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the four 12.4 mm screws securing the subwoofer.
    • Use a spudger to lift the subwoofer up and off of the driver assembly.
    • This might require some force, as there is adhesive holding the subwoofer to the assembly.
    • During reassembly, apply an adhesive to the new subwoofer before reinstallation.
  8. Beats Pill 2024 Motherboard Replacement, Battery: step 8, image 1 of 2 Beats Pill 2024 Motherboard Replacement, Battery: step 8, image 2 of 2
    • Flip the speaker over.
  9. Beats Pill 2024 Motherboard Replacement: step 9, image 1 of 2 Beats Pill 2024 Motherboard Replacement: step 9, image 2 of 2
    • Use a hairdryer to lightly heat the bottom foot of the speaker.
    • Insert a spudger into the seam between the bottom foot and speaker body.
    • Pry around the perimeter of the foot until it fully releases.
    • Reapply adhesive to the foot before reinstalling it.
  10. Beats Pill 2024 Motherboard Replacement: step 10, image 1 of 2 Beats Pill 2024 Motherboard Replacement: step 10, image 2 of 2
    • Remove the twelve 8.6 mm T5 Torx screws that secure the battery cover.
  11. Beats Pill 2024 Motherboard Replacement: step 11, image 1 of 3 Beats Pill 2024 Motherboard Replacement: step 11, image 2 of 3 Beats Pill 2024 Motherboard Replacement: step 11, image 3 of 3
    • To remove the battery, pull on the tape material wrapped around the middle of it.
  12. Beats Pill 2024 Motherboard Replacement, Motherboard: step 12, image 1 of 1
    • Remove the two T5 Torx screws that secure the battery compartment.
  13. Beats Pill 2024 Motherboard Replacement: step 13, image 1 of 3 Beats Pill 2024 Motherboard Replacement: step 13, image 2 of 3 Beats Pill 2024 Motherboard Replacement: step 13, image 3 of 3
    • Use a spudger to dislodge the battery compartment from its housing.
    • Before complete removal, disconnect the battery compartment motherboard connector.
  14. Beats Pill 2024 Motherboard Replacement: step 14, image 1 of 1
    • Lift the black ZIF locking tab in the top-right corner of the motherboard.
    • Disconnect the ribbon cable.
  15. Beats Pill 2024 Motherboard Replacement: step 15, image 1 of 1
    • Remove the seven 12.4 mm Phillips screws securing the motherboard.
  16. Beats Pill 2024 Motherboard Replacement: step 16, image 1 of 1
    • Gently lift the motherboard perpendicular to the housing, with care not to strain the connected cable.
    • Disengage the ZIF locking flap and disconnect the ribbon cable.
  17. Beats Pill 2024 Motherboard Replacement: step 17, image 1 of 1
    • Remove the motherboard.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 31
All Time: 226
