Introduction
For general disassembly guide follow this link. This guide will follow the steps taken in the general disassembly of the Beats Pill 1.0.
Using the spudger, create space between the speaker covers and then remove.
On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
Remove the two screws with a Phillips #0 screwdriver.
Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
Use the spudger to pry the device apart along its seam, starting in the middle.
Open the device to separate the front and back panels.
Carefully remove the yellow, red, black, and white wires from the motherboard.
Tool used on this step:Phillips #0 Screwdriver$5.49
Using a Phillips #0 Screwdriver, unscrew the four screws holding the bands that go over the battery.
Using the same screwdriver, remove the motherboard screws along with the rubber stoppers.
Tool used on this step:Tweezers$4.99
Gently remove the motherboard from the case
Remove the yellow NFC module with Tweezers
Using a soldering iron attach the new battery to the motherboard with the red wire connecting to the 0.2 volts (+) and black wire connecting to the ground (-). See the soldering guide for more information on how to perform this step.
28 other people completed this guide.
10 Guide Comments
Could you please tell what is the yellow card in the last picture?
Looks like the Bluetooth antenna
