Up to 20% off select tools
Bear 1000 Power Entry Module Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
9
Past 30 Days:
55
All Time:
453
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing the Power entry Module in a Bear 1000 Ventilator. Found on page 88 in the full service manual.
    1. Bear 1000 Power Entry Module Replacement, Air and O2 Blender: step 1, image 1 of 1
      • Remove the ribbon cable at the connection on the oxygen blender control board.
      Ask FixBot
    2. Bear 1000 Power Entry Module Replacement: step 2, image 1 of 1
      • Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
      Ask FixBot
    3. Bear 1000 Power Entry Module Replacement: step 3, image 1 of 1
      • The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
      Ask FixBot
    1. Bear 1000 Power Entry Module Replacement, Air and O2 Inlet Manifold: step 4, image 1 of 1
      • Remove the pneumatic and electrical connections labeled.
      Ask FixBot
      • Remove the water trap bowls on the rear of the unit.
      Ask FixBot
    2. Bear 1000 Power Entry Module Replacement: step 6, image 1 of 1
      • Remove the four screws and remove the manifold.
      Ask FixBot
      • Remove the two screws holding the power supply to the manifold.
      Ask FixBot
      • Mark or label the 6 faston connections as to position and remove
      Ask FixBot
      • Mark or label the two wires going to the power switch and remove at the power switch end
      Ask FixBot
      • Using an allen wrench, remove the power cord retaining bracket.
      Ask FixBot
    1. Bear 1000 Power Entry Module Replacement: step 11, image 1 of 1
      • Using an allen wrench, remove the mounting screwa and nuts from the Power Entry Module.
      Ask FixBot
      • After removing the heat shrink tubing, unsolder the two lower wires from the Power Entry Module, noting locations.
      Ask FixBot
      • Solder the wires to the replacement module, covering the joints with heat shrink tubing.
      Ask FixBot
      • Transfer the voltage selector drum from the original module to the replacement and reinstall.
      Ask FixBot
Author
with
Eli Ferman
607 Reputation
4 Guides authored
Cal Poly, Team S7-G12, Paton Fall 2020 Member of Cal Poly, Team S7-G12, Paton Fall 2020
CPSU-PATON-F20S7G12
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 55
All Time: 453
