Bear 1000 Air and O2 Inlet Manifold Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
    1. Bear 1000 Air and O2 Inlet Manifold Replacement, Air and O2 Blender: step 1, image 1 of 1
      • Remove the ribbon cable at the connection on the oxygen blender control board.
      Ask FixBot
    2. Bear 1000 Air and O2 Inlet Manifold Replacement: step 2, image 1 of 1
      • Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
      Ask FixBot
    3. Bear 1000 Air and O2 Inlet Manifold Replacement: step 3, image 1 of 1
      • The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
      Ask FixBot
    1. Bear 1000 Air and O2 Inlet Manifold Replacement, Air and O2 Inlet Manifold: step 4, image 1 of 1
      • Remove the pneumatic and electrical connections labeled.
      Ask FixBot
      • Remove the water trap bowls on the rear of the unit.
      Ask FixBot
    2. Bear 1000 Air and O2 Inlet Manifold Replacement: step 6, image 1 of 1
      • Remove the four screws and remove the manifold.
      Ask FixBot
      • Remove the two screws holding the power supply to the manifold.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Calibrate and test the system to see if the replacement was successful
William Burns
285 Reputation
2 Guides authored
Cal Poly, Team S7-G12, Paton Fall 2020 Member of Cal Poly, Team S7-G12, Paton Fall 2020
CPSU-PATON-F20S7G12
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 377
