Beachwaver S-Series Clamp Spring Repair
      • Ensure the curling iron is turned off and unplugged.
      • Ensure the curling iron is completely cool before attempting this repair to avoid the risk of burns.
      Ask FixBot
    1. Beachwaver S-Series Clamp Spring Repair: step 2, image 1 of 3 Beachwaver S-Series Clamp Spring Repair: step 2, image 2 of 3 Beachwaver S-Series Clamp Spring Repair: step 2, image 3 of 3
      • Insert the tip of your size 000 Phillips screwdriver into the pin hole at the base of the clamp.
      • Apply pressure to the top of your screwdriver to push the pin that secures the clamp to the rod out of your curling iron.
      • Store the clamp some place you will not lose it.
      Ask FixBot
    2. Beachwaver S-Series Clamp Spring Repair: step 3, image 1 of 3 Beachwaver S-Series Clamp Spring Repair: step 3, image 2 of 3 Beachwaver S-Series Clamp Spring Repair: step 3, image 3 of 3
      • Lift the clamp off of the rod.
      Ask FixBot
    3. Beachwaver S-Series Clamp Spring Repair: step 4, image 1 of 2 Beachwaver S-Series Clamp Spring Repair: step 4, image 2 of 2
      • Pull the spring from the base of the rod, where the clamp previously rested.
      • Install your replacement spring into the previous spring's location.
      • If your original spring is intact, it may have become misaligned. If so, reinsert the spring into the location shown in the images.
      Ask FixBot
Attached Documents
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 45
Past 30 Days: 158
All Time: 2,224
