Introduction
Hello and welcome to the battery replacement guide on the Steelseries Arctis Pro / Black headset. The defect is noticeable through spontaneous shutdown and short battery life.
Remove the earpads. These are fixed by a band on the short sides.
The Band is fixed with the earpads. You cant loose it.
To remove:
Grab the earpad on one of the shorter sides.
Pull on the earpad carefully, until the band slips out of the guide bar.
Remove the Cover of the right Earpice.
For this, remove the three screws with an J0-Screwdriver
All Screws are the same size and can be used at any of those locations.
The speaker is magnetic. We recommend carefully removing the screws and storing them safely at a safe distance. They can be attracted by the magnet.
Use a soldering iron to carefully desolder the three wires of the old battery from the circuit board.
Remember the colors and their positions, so you can resolder it in the correct locations.
Desolder the cables one by one and make sure to isolate them instantly afterwards. This is very important, because we don´t want to cause a short.
Pull the battery out. You will need some strength - it is attaced using doubel sided tape.
Apply a small piece of double-sided tape to the designated area of the mount.
Insert the new battery and press it gently to ensure it is securely in place.
Resolder the three cables on the circuit board
In my case the new battery is from CELLONIC. But other companys work as well. The original battery was a 1100mAh 4.07Wh rated Voltage 3.7Vd.c.
Reinsert the speaker into the case.
Secure it with the three screws you removed earlier. These screws are embedded in plastic, so don't overtighten them.
Now test the function of the new battery before reattaching the ear pads:
Connect the headset to a charging cable.
Check if the charging process starts and if the headset can be turned on.
Optional: Use a USB meter to check charging speed, voltage, or mAh value.
First, insert the earpad into the corresponding guide at the top.
Carefully pull down until the band slips in the bottom bar.
Inserting the cushion requires a bit of finesse – take your time to ensure it is positioned neatly and evenly.
Conrgatulations! You have sucsessfully changed the battery on your Headset. Have fun with your new battery.
5 other people completed this guide.
Special thanks to these translators:
100%
Toby is helping us fix the world! Want to contribute?
Start translating ›
