Up to 20% off select tools
Battery Disconnect
Views: 3.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
101
All Time:
3,516
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Battery Disconnect
Parts
Tools
Introduction
Go to step 1 ↓
Prereq for disconnecting the battery of your Samsung Galaxy A10e.
    1. Battery Disconnect, SIM Card: step 1, image 1 of 2 Battery Disconnect, SIM Card: step 1, image 2 of 2
      • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
      • Press to eject the tray.
      Ask FixBot
    2. Battery Disconnect: step 2, image 1 of 2 Battery Disconnect: step 2, image 2 of 2
      • Remove the SIM card tray from the phone.
      • The SIM card(s) and SD card will fall out of the tray easily.
      • When reinserting the tray, ensure the SIM card and SD card are in the correct slots and oriented correctly.
      • For dual-SIM versions of this phone, there may be two SIM cards. Ensure the SIM cards are placed in the slots corresponding to the correct phone lines.
      Ask FixBot
    1. Battery Disconnect, Back Cover: step 3, image 1 of 1
      • The back cover is held in place by plastic clips.
      • Insert an opening pick between the screen and the back cover on the bottom of the phone where the charging port is located.
      Ask FixBot
    2. Battery Disconnect: step 4, image 1 of 1
      • Slide the opening pick to the bottom left corner to release the clips.
      Ask FixBot
    3. Battery Disconnect: step 5, image 1 of 1
      • Slide the opening pick along the left edge to the top left corner of the phone, to release the clips.
      Ask FixBot
    4. Battery Disconnect: step 6, image 1 of 1
      • Slide the opening pick from the top left corner to the top right corner to release the plastic clips.
      Ask FixBot
    5. Battery Disconnect: step 7, image 1 of 1
      • Slide the opening pick from the top right corner to the bottom right corner to release the remaining clips.
      Ask FixBot
    6. Battery Disconnect: step 8, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    1. Battery Disconnect, Motherboard Cover: step 9, image 1 of 1
      • Remove screws from the motherboard antenna cover.
      • 3 Phillips #00, 3mm length.
      Ask FixBot
    2. Battery Disconnect: step 10, image 1 of 1
      Tool used on this step:
      Buy
      • Use the tip of a spudger or tweezers to remove the antenna cover.
      Ask FixBot
    3. Battery Disconnect: step 11, image 1 of 1
      • Remove screws from the motherboard cover.
      Ask FixBot
    4. Battery Disconnect: step 12, image 1 of 1
      • Use the tip of a spudger or tweezers to remove the motherboard cover.
      Ask FixBot
    1. Battery Disconnect, Battery Disconnect: step 13, image 1 of 2 Battery Disconnect, Battery Disconnect: step 13, image 2 of 2
      • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
      Ask FixBot
    2. Battery Disconnect: step 14, image 1 of 1
      • Gently flex the battery connector away from its socket.
      Ask FixBot
7 other people completed this guide.
Author
with
Thomas Boland
1,932 Reputation
5 Guides authored
2 Guide Comments
Do I need to heat up the screen of my phone to make it easier for me to get the back cover off of my phone?
Pifase - Reply Share
no, it just clips on, there's no adhesive
Ely Wickander - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 101
All Time: 3,516
