Up to 20% off select tools
Basis Peak Frame Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
87
All Time:
698
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The frame of the Basis Peak is a two-piece container for the electronics. On the face, the frame is clear to allow for the user to see the screen. On the back, the sensor for the user's heart rate is located so it will be touching the skin. If the frame is damaged or the sensor is nonfunctional, the electronics (including the battery, motherboard, and screen) can be moved into a new frame. This guide details said process in which the user must unscrew the back plate, unhook several cables, and remove the motherboard complex.
    1. Basis Peak Frame Replacement, Frame: step 1, image 1 of 1
      • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
      • Maintain this orientation to follow the guide.
      Ask FixBot
    2. Basis Peak Frame Replacement: step 2, image 1 of 2 Basis Peak Frame Replacement: step 2, image 2 of 2
      • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
      Ask FixBot
    3. Basis Peak Frame Replacement: step 3, image 1 of 1
      • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
      Ask FixBot
    4. Basis Peak Frame Replacement: step 4, image 1 of 1
      • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
      • The clips have small lips that you can put the spudger under to get more leverage.
      • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
      Ask FixBot
Author
with
Alexander Halliwell
213 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 87
All Time: 698
