Basis Peak Band Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
87
All Time:
575
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
The bands of the Basis Peak allow for several size adjustments for a snug fit to the user's wrist. A properly adjusted band is crucial to the functioning of the sensor on the underside of the watch. If the band is damaged or visibly tarnished, users can easily replace it with this guide. Two spring latches on the underside of the band halves must be released and the band halves will come right off.
Tools
    1. Basis Peak Band Replacement, Band: step 1, image 1 of 1
      • Flip the watch over to view the back panel and sensor. Arrange the watch so that the band clasp is away from you.
      • Keep the watch in this position to help you follow the rest of the guide.
      Ask FixBot
    2. Basis Peak Band Replacement: step 2, image 1 of 1
      • Release the spring latches on the underside of each band to remove the bands from the frame.
      Ask FixBot
To reattach the bands, follow these instructions in reverse order.
Alexander Halliwell
213 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 87
All Time: 575
