Up to 20% off select tools
Base Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
91
All Time:
1,080
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Base Replacement
Tools
Introduction
Go to step 1 ↓
This guide shows the steps to replace the parts in the base.
    1. Base Replacement, Base: step 1, image 1 of 2 Base Replacement, Base: step 1, image 2 of 2
      • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
      Ask FixBot
    2. Base Replacement: step 2, image 1 of 1
      • Use the spudger to separate the bottom from the top.
      • There are two clips, located top and bottom, that you have to compress with the spudger.
      Ask FixBot
2 other people completed this guide.
Author
with
Josh Showalter
442 Reputation
3 Guides authored
IUPUI, Team 1-4, Baechle Spring 2016 Member of IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 91
All Time: 1,080
