Up to 20% off select tools
Base Disassembly
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
91
All Time:
1,429
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Base Disassembly
Tools
Introduction
Go to step 1 ↓
In this prerequisite guide, we will remove the 4 screws on the bottom of the base. Then we will remove the gray cover from the base.
    1. Base Disassembly, Base Disassembly: step 1, image 1 of 1
      • Take out the three 15 mm Phillips #1 screws.
      • Remove the 15mm T10 screw.
      • Place the 4 screws on the magnetic mat.
      Ask FixBot
    2. Base Disassembly: step 2, image 1 of 1
      • Remove the gray base by lifting upwards and placing to the side.
      Ask FixBot
Author
with
Devin Poulin
353 Reputation
1 Guide authored
USF Tampa, Team 15-1, Remmell Spring 2016 Member of USF Tampa, Team 15-1, Remmell Spring 2016
USFT-REMMELL-S16S15G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 91
All Time: 1,429
