Barnes And Noble Nook Glowlight 3 Disassembly
  1. Barnes And Noble Nook Glowlight 3 Disassembly, Barnes And Noble Nook Glowlight 3 Disassembly: step 1, image 1 of 1
    • This is the Nook Glowlight 3. It features an E-ink display with a resolution of 300 ppi. This device is touchscreen. It comes with 8GB of on device storage. It is wifi compatible
    Ask FixBot
  2. Barnes And Noble Nook Glowlight 3 Disassembly: step 2, image 1 of 2 Barnes And Noble Nook Glowlight 3 Disassembly: step 2, image 2 of 2
    • First, grab your Jimmy or any other thin tool and slide it along the edge of the device where the two halves meet, (shown in the picture).
    • Push firmly until the tool slides into the crack. Then rotate the tool as you slide it down to separate the clips securing the device.
    • Do this all around the device until the device splits into two halves.
    Ask FixBot
  3. Barnes And Noble Nook Glowlight 3 Disassembly: step 3, image 1 of 2 Barnes And Noble Nook Glowlight 3 Disassembly: step 3, image 2 of 2
    • When both of the halves are able to be separated move the back cover aside.
    • To reassemble the device, push down on the back cover until it snaps into place.
    Ask FixBot
  4. Barnes And Noble Nook Glowlight 3 Disassembly: step 4, image 1 of 3 Barnes And Noble Nook Glowlight 3 Disassembly: step 4, image 2 of 3 Barnes And Noble Nook Glowlight 3 Disassembly: step 4, image 3 of 3
    • Disconnect the battery with a flick of the spudger.
    Ask FixBot
  5. Barnes And Noble Nook Glowlight 3 Disassembly: step 5, image 1 of 1
    • Remove the screws marked in red that secure the system board to the outer plastic.
    Ask FixBot
  6. Barnes And Noble Nook Glowlight 3 Disassembly: step 6, image 1 of 2 Barnes And Noble Nook Glowlight 3 Disassembly: step 6, image 2 of 2
    • On both sides, there are two straight and skinny button panels. These control the side up/down buttons. Please disconnect both of these ribbon cables.
    Ask FixBot
  7. Barnes And Noble Nook Glowlight 3 Disassembly: step 7, image 1 of 3 Barnes And Noble Nook Glowlight 3 Disassembly: step 7, image 2 of 3 Barnes And Noble Nook Glowlight 3 Disassembly: step 7, image 3 of 3
    • Now disconnect the display ribbon cables. ( one is hidden )
    Ask FixBot
  8. Barnes And Noble Nook Glowlight 3 Disassembly: step 8, image 1 of 1
    • Now lift the logic board
    Ask FixBot
  9. Barnes And Noble Nook Glowlight 3 Disassembly: step 9, image 1 of 2 Barnes And Noble Nook Glowlight 3 Disassembly: step 9, image 2 of 2
    • Now remove the battery by sliding a spudger underneath the battery and breaking the adhesive.
    Ask FixBot
  10. Barnes And Noble Nook Glowlight 3 Disassembly: step 10, image 1 of 3 Barnes And Noble Nook Glowlight 3 Disassembly: step 10, image 2 of 3 Barnes And Noble Nook Glowlight 3 Disassembly: step 10, image 3 of 3
    • Now remove the screws on the button panels and remove them from the device.
    Ask FixBot
  11. Barnes And Noble Nook Glowlight 3 Disassembly: step 11, image 1 of 1
    • Remove the rest of the screws connecting the display to the frame. Remember to take out both of the button boards.
    Ask FixBot
  12. Barnes And Noble Nook Glowlight 3 Disassembly: step 12, image 1 of 2 Barnes And Noble Nook Glowlight 3 Disassembly: step 12, image 2 of 2
    • Push firmly on the display. Going all around the edges until the display becomes loose. (the screen was already cracked)
    Ask FixBot
Joan Lee
463 Reputation
2 Guides authored
1 Guide Comment
does anyone know where I can purchase the screen?
John McNamara - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 1,595
