Up to 20% off select tools
Bambu A1 Mini Hotend Assembly Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
31
Past 7 Days:
166
Past 30 Days:
594
All Time:
3,348
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
The Hotend Assembly (Hotend) includes the nozzle and is the final part the filament goes through before reaching the build plate.
    1. Bambu A1 Mini Hotend Assembly Replacement, Remove filment: step 1, image 1 of 2 Bambu A1 Mini Hotend Assembly Replacement, Remove filment: step 1, image 2 of 2
      • Cut the filament by fully pressing the handle on the right side of the toolhead.
      • In the control window, press the up button for the extruder.
      • You do not want to need to rip the filament out of the nozzle.
      Ask FixBot
    2. Bambu A1 Mini Hotend Assembly Replacement, Take off front pannel: step 2, image 1 of 2 Bambu A1 Mini Hotend Assembly Replacement, Take off front pannel: step 2, image 2 of 2
      • Lift the front cover in the circled spot in the photo and pull out the front cover.
      Ask FixBot
    3. Bambu A1 Mini Hotend Assembly Replacement, Take off ruber sock: step 3, image 1 of 2 Bambu A1 Mini Hotend Assembly Replacement, Take off ruber sock: step 3, image 2 of 2
      • Remove the silicone sock from the nozzle.
      Ask FixBot
    4. Bambu A1 Mini Hotend Assembly Replacement, Undo latch: step 4, image 1 of 3 Bambu A1 Mini Hotend Assembly Replacement, Undo latch: step 4, image 2 of 3 Bambu A1 Mini Hotend Assembly Replacement, Undo latch: step 4, image 3 of 3
      • Open the front wire frame latch.
      • Then, open the solid latch.
      Ask FixBot
    5. Bambu A1 Mini Hotend Assembly Replacement, Remove Hotend: step 5, image 1 of 2 Bambu A1 Mini Hotend Assembly Replacement, Remove Hotend: step 5, image 2 of 2
      • Pull out the old nozzle.
      Ask FixBot
    6. Bambu A1 Mini Hotend Assembly Replacement, Add New hotend: step 6, image 1 of 2 Bambu A1 Mini Hotend Assembly Replacement, Add New hotend: step 6, image 2 of 2
      • Place the new nozzle into the hotend.
      Ask FixBot
2 other people completed this guide.
Author
with
not-ethan
679 Reputation
3 Guides authored
1 Guide Comment
Perhaps this may be cross-referenced to various guides from the Bambu Lab wiki, such as the guide to clean the A1 series hotend.
Tai Lam - Reply Share
Past 24 Hours: 31
Past 7 Days: 166
Past 30 Days: 594
All Time: 3,348
