Up to 20% off select tools
Ballpoint Pen Spring Replacement
Views: 7.5K
View statistics:
Past 24 Hours:
14
Past 7 Days:
134
Past 30 Days:
582
All Time:
7,546
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace a broken or faulty spring in any brand of ballpoint pen. In this example, we are working with the Paper Mate Profile Ballpoint Pen.
The spring allows for the pen to actively write and transfer ink to a page. A broken or faulty spring will not allow this action to occur.
Before you begin, make sure to test the pen's ability to 'click on' and write. This will allow you to determine if the spring is the issue at hand.
Follow along carefully with the steps below in order to effectively replace a pen spring.
    1. Ballpoint Pen Spring Replacement, Spring: step 1, image 1 of 1
      • Unscrew the pen cap at the top of the pen.
      Ask FixBot
    2. Ballpoint Pen Spring Replacement: step 2, image 1 of 1
      • Remove the primary ink needle that holds the spring.
      Ask FixBot
    3. Ballpoint Pen Spring Replacement: step 3, image 1 of 1
      • Pull the spring off of the needle.
      Ask FixBot
    4. Ballpoint Pen Spring Replacement: step 4, image 1 of 2 Ballpoint Pen Spring Replacement: step 4, image 2 of 2
      • Slide a new spring onto the ink needle.
      Ask FixBot
    5. Ballpoint Pen Spring Replacement: step 5, image 1 of 1
      • Put the ink needle with a new spring back inside the pen.
      Ask FixBot
    6. Ballpoint Pen Spring Replacement: step 6, image 1 of 2 Ballpoint Pen Spring Replacement: step 6, image 2 of 2
      • Screw the pen cap back on.
      Ask FixBot
    7. Ballpoint Pen Spring Replacement: step 7, image 1 of 2 Ballpoint Pen Spring Replacement: step 7, image 2 of 2
      • Test the pen on paper.
      Ask FixBot
Finish Line
Author
with
Katelyn Zastrow
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 134
Past 30 Days: 582
All Time: 7,546
