Ball Bearing Cone Adjustment and Installation
    1. Ball Bearing Cone Adjustment and Installation, Rear Wheel: step 1, image 1 of 2 Ball Bearing Cone Adjustment and Installation, Rear Wheel: step 1, image 2 of 2
      • Flip the quick release lever on the wheel.
      Ask FixBot
    2. Ball Bearing Cone Adjustment and Installation: step 2, image 1 of 1
      • Squeeze the brake arms together and lift the brake cable from the caliper arms.
      Ask FixBot
    3. Ball Bearing Cone Adjustment and Installation: step 3, image 1 of 1
      • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
      Ask FixBot
    1. Ball Bearing Cone Adjustment and Installation, Ball Bearing Cone Adjustment and Installation: step 4, image 1 of 3 Ball Bearing Cone Adjustment and Installation, Ball Bearing Cone Adjustment and Installation: step 4, image 2 of 3 Ball Bearing Cone Adjustment and Installation, Ball Bearing Cone Adjustment and Installation: step 4, image 3 of 3
      • Unscrew the quick release nut from the quick release axle. Remove the quick release axle.
      • After removing the axle you should notice that there are two springs on it. Be careful not to lose these.
      Ask FixBot
    2. Ball Bearing Cone Adjustment and Installation: step 5, image 1 of 2 Ball Bearing Cone Adjustment and Installation: step 5, image 2 of 2
      • Fit the cone wrench to the cone, and fit the open end wrench to the top lock nut. Hold the cone in place with the cone wrench and turn the open end wrench to loosen and remove the top lock nut.
      • Keep track of which side each lock nut goes on. The order is important because the threading for each nut is specific for each side.
      Ask FixBot
    3. Ball Bearing Cone Adjustment and Installation: step 6, image 1 of 2 Ball Bearing Cone Adjustment and Installation: step 6, image 2 of 2
      • Unscrew the cone, and set it aside.
      • Keep track of which side each cone goes on. The order is important because the threading for each cone is specific for each side.
      Ask FixBot
    4. Ball Bearing Cone Adjustment and Installation: step 7, image 1 of 2 Ball Bearing Cone Adjustment and Installation: step 7, image 2 of 2
      • Remove the axle and all ball bearings.
      • Caution: There are 10 ball bearings on each side, be careful not to lose any if you plan on putting the old ones back in!
      Ask FixBot
    5. Ball Bearing Cone Adjustment and Installation: step 8, image 1 of 3 Ball Bearing Cone Adjustment and Installation: step 8, image 2 of 3 Ball Bearing Cone Adjustment and Installation: step 8, image 3 of 3
      • Inspect cone surfaces and all ball bearings for dents, cracks or blemishes.
      • If any are damaged, replace them.
      Ask FixBot
    6. Ball Bearing Cone Adjustment and Installation: step 9, image 1 of 1
      • Clean bearings, the bearing races, and cones by wiping them off with a rag.
      Ask FixBot
    7. Ball Bearing Cone Adjustment and Installation: step 10, image 1 of 2 Ball Bearing Cone Adjustment and Installation: step 10, image 2 of 2
      • Liberally apply grease to the bearings, races, and cones.
      Ask FixBot
    8. Ball Bearing Cone Adjustment and Installation: step 11, image 1 of 1
      • Insert the axle back into the wheel, with the still attached nut and cone on the bottom side of the wheel.
      Ask FixBot
    9. Ball Bearing Cone Adjustment and Installation: step 12, image 1 of 1
      • Insert 10 bearings into the topmost bearing races.
      • Make sure that you insert exactly 10. If you insert too many or too few, it can damage the bearings.
      Ask FixBot
    10. Ball Bearing Cone Adjustment and Installation: step 13, image 1 of 2 Ball Bearing Cone Adjustment and Installation: step 13, image 2 of 2
      • Carefully drop the axle out from the bottom of the wheel.
      • Re-insert the axle from the top side of the wheel, so that the attached nut and bearing and cone set are now sticking out of the top.
      • Now flip the wheel upside down.
      Ask FixBot
    11. Ball Bearing Cone Adjustment and Installation: step 14, image 1 of 1
      • Insert the remaining 10 bearings into the bearing races on the opposite side.
      • Caution: make sure you insert exactly 10 bearings into each bearing race.
      Ask FixBot
    12. Ball Bearing Cone Adjustment and Installation: step 15, image 1 of 2 Ball Bearing Cone Adjustment and Installation: step 15, image 2 of 2
      • Hand tighten bearing cone onto the free end of the axle, so that it touches the bearings without putting any pressure on them.
      • Ideally, there should be no movement or give in the axle when you pull on it or try to wiggle it. Additionally, the axle should be able to spin freely in the wheel, with minimal resistance.
      Ask FixBot
    13. Ball Bearing Cone Adjustment and Installation: step 16, image 1 of 2 Ball Bearing Cone Adjustment and Installation: step 16, image 2 of 2
      • Slide the washer onto the axle.
      • Hand tighten the lock nut against the cone and washer.
      Ask FixBot
    14. Ball Bearing Cone Adjustment and Installation: step 17, image 1 of 1
      • Once in proper position, use the cone wrench and open wrench to tighten the lock nut.
      • Tighten the lock nut VERY tightly. Otherwise the wheel can come out of alignment while you are riding.
      Ask FixBot
    15. Ball Bearing Cone Adjustment and Installation: step 18, image 1 of 1
      • Check the way that the axle spins in the wheel. The action should be smooth, with virtually no slop when wiggled. If it is to tight or too sloppy then you need to repeat the previous step.
      Ask FixBot
    16. Ball Bearing Cone Adjustment and Installation: step 19, image 1 of 3 Ball Bearing Cone Adjustment and Installation: step 19, image 2 of 3 Ball Bearing Cone Adjustment and Installation: step 19, image 3 of 3
      • Reinsert the quick release axle, and put the wheel back on the bike.
      • The springs should have the smaller tapered end closest to the hub
      Ask FixBot
Finish Line
3 other people completed this guide.
Tyler Parra
472 Reputation
1 Guide authored
Cal Poly, Team 5-13, Maness Fall 2010 Member of Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Members
120 Guides authored
1 Guide Comment
Display and text were really helpful. I was wondering what happened to the sprocket assembly. from steps 1 through 3. This worked fine for the front wheel when I did it, but I'm not sure about working on the rear wheel. Does the sprocket assembly stay on the axle when you take off the lock nut and cone from the other side? Thanks Bob
Bob Walsh - Reply Share
Past 24 Hours: 7
Past 7 Days: 29
Past 30 Days: 99
All Time: 18,454
