Up to 20% off select tools
Backbone One Phone Connector Replacement
Views: 7.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
48
Past 30 Days:
239
All Time:
7,261
Comments: 12
6 comments on steps, 6 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken phone connector on your Backbone One.
    1. Backbone One Phone Connector Replacement, Remove the screws: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
      Ask FixBot
    2. Backbone One Phone Connector Replacement, Rotate the upper part: step 2, image 1 of 3 Backbone One Phone Connector Replacement, Rotate the upper part: step 2, image 2 of 3 Backbone One Phone Connector Replacement, Rotate the upper part: step 2, image 3 of 3
      • Lift up the upper cover of the controller.
      • Swing the upper cover over and place it on the controller case.
      • Make sure that the interconnecting cable has no tension.
      Ask FixBot
    1. Backbone One Phone Connector Replacement, Remove the screws: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the two 4.8 mm-long screws securing the phone connector.
      Ask FixBot
    2. Backbone One Phone Connector Replacement, Unthread the phone connector: step 4, image 1 of 3 Backbone One Phone Connector Replacement, Unthread the phone connector: step 4, image 2 of 3 Backbone One Phone Connector Replacement, Unthread the phone connector: step 4, image 3 of 3
      • Use your fingers to thread the phone connecter through the opening in the plastic cover at the right side of the rear cover.
      Ask FixBot
    3. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: step 5, image 1 of 2 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to disconnect the first phone connector cable from the mainboard.
      Ask FixBot
    4. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: step 6, image 1 of 2 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: step 6, image 2 of 2
      • Use a pair of tweezers to disconnect the second phone connector cable from the mainboard.
      Ask FixBot
    5. Backbone One Phone Connector Replacement, Remove the phone connector cable: step 7, image 1 of 1
      • Remove the phone connector cable.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Author
with
Adriana Zwink
69,920 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
6 Guide Comments
Where can i buy a new part
reye_s - Reply Share
Unfortunately we haven't found any replacement parts yet. If you find a website that offers replacement parts feel free to share your experience with us.
Adriana Zwink - Reply Share
Where can I find the connector
Big_deppresion_time_14 Xxx - Reply Share
My son bent the connector cable. Where do I buy a new one?
Please update as soon as possible!
Krystal Glavic - Reply Share
Has anyone found a place to buy a replacement lightning connector yet?
Ump_ - Reply Share
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 239
All Time: 7,261
