Up to 20% off select tools
Backbone One Direction Pad Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
122
All Time:
3,777
Comments: 3
3 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the direction pad on your Backbone One.
    1. Backbone One Direction Pad Replacement, Unfasten the screws: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
      Ask FixBot
    2. Backbone One Direction Pad Replacement, Rotate the upper cover: step 2, image 1 of 3 Backbone One Direction Pad Replacement, Rotate the upper cover: step 2, image 2 of 3 Backbone One Direction Pad Replacement, Rotate the upper cover: step 2, image 3 of 3
      • Lift up the upper part of the controller.
      • Swing over the upper cover and place it on the controller case.
      • Take care that the interconnecting cable has no tension.
      Ask FixBot
    3. Backbone One Direction Pad Replacement, Remove the protective tape: step 3, image 1 of 3 Backbone One Direction Pad Replacement, Remove the protective tape: step 3, image 2 of 3 Backbone One Direction Pad Replacement, Remove the protective tape: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
      Ask FixBot
    4. Backbone One Direction Pad Replacement, Open the ZIF connector: step 4, image 1 of 2 Backbone One Direction Pad Replacement, Open the ZIF connector: step 4, image 2 of 2
      • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
      Ask FixBot
    5. Backbone One Direction Pad Replacement, Disconnect the interconnect cable: step 5, image 1 of 2 Backbone One Direction Pad Replacement, Disconnect the interconnect cable: step 5, image 2 of 2
      • Use your fingers to disconnect the interconnect cable from its connector.
      Ask FixBot
    6. Backbone One Direction Pad Replacement: step 6, image 1 of 2 Backbone One Direction Pad Replacement: step 6, image 2 of 2
      • Remove the upper half of the left controller assembly.
      Ask FixBot
    1. Backbone One Direction Pad Replacement, Remove the screw: step 7, image 1 of 2 Backbone One Direction Pad Replacement, Remove the screw: step 7, image 2 of 2
      • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
      • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
      Ask FixBot
    2. Backbone One Direction Pad Replacement, Remove the trigger: step 8, image 1 of 2 Backbone One Direction Pad Replacement, Remove the trigger: step 8, image 2 of 2
      • Remove the left trigger.
      Ask FixBot
    1. Backbone One Direction Pad Replacement, Remove the bumper: step 9, image 1 of 2 Backbone One Direction Pad Replacement, Remove the bumper: step 9, image 2 of 2
      • Use your fingers to remove the left bumper.
      Ask FixBot
    1. Backbone One Direction Pad Replacement, Remove the screws: step 10, image 1 of 1
      • Use a Phillips screwdriver to remove the four 3.9 mm-long screws.
      Ask FixBot
    2. Backbone One Direction Pad Replacement, Remove the mainboard: step 11, image 1 of 2 Backbone One Direction Pad Replacement, Remove the mainboard: step 11, image 2 of 2
      • Remove the mainboard.
      Ask FixBot
    1. Backbone One Direction Pad Replacement, Remove the direction pad: step 12, image 1 of 3 Backbone One Direction Pad Replacement, Remove the direction pad: step 12, image 2 of 3 Backbone One Direction Pad Replacement, Remove the direction pad: step 12, image 3 of 3
      Buy
      • Use a pair of blunt nose tweezers to remove the direction pad.
      Ask FixBot
Repair didn’t go as planned? Ask our Answers community for help.
Author
with
Adriana Zwink
69,920 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 122
All Time: 3,777
