Up to 20% off select tools
Back Panel Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
90
All Time:
994
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
A guide for replacing the back panel on the G3 Gamecube Controller by Gamestop.
    1. Back Panel Replacement, Back Panel: step 1, image 1 of 3 Back Panel Replacement, Back Panel: step 1, image 2 of 3 Back Panel Replacement, Back Panel: step 1, image 3 of 3
      • First, remove the 6 screws in the back panel and pull the back panel off.
      • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
      Ask FixBot
    2. Back Panel Replacement: step 2, image 1 of 3 Back Panel Replacement: step 2, image 2 of 3 Back Panel Replacement: step 2, image 3 of 3
      • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
      Ask FixBot
    3. Back Panel Replacement: step 3, image 1 of 3 Back Panel Replacement: step 3, image 2 of 3 Back Panel Replacement: step 3, image 3 of 3
      • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
      Ask FixBot
Author
with
David Mistretta
116 Reputation
1 Guide authored
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 90
All Time: 994
