Up to 20% off select tools
Back Panel Removal
Views: 1.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
111
All Time:
1,592
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Back Panel Removal
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Removing the back panel is the starting point for any repair work on interior hardware.
    1. Back Panel Removal, Back Panel Removal: step 1, image 1 of 2 Back Panel Removal, Back Panel Removal: step 1, image 2 of 2
      • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
      Ask FixBot
    2. Back Panel Removal: step 2, image 1 of 1
      • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
      Ask FixBot
    3. Back Panel Removal: step 3, image 1 of 1
      • Use the spudger to pry apart the screen from all around the device.
      • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
      Ask FixBot
Finish Line
Author
with
Francisco Rosado
370 Reputation
4 Guides authored
USF Tampa, Team 1-3, Lacy Fall 2016 Member of USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 111
All Time: 1,592
