Back Panel Removal
    1. Back Panel Removal, Battery: step 1, image 1 of 1
      • Power down the computer and unplug the power adapter.
      Ask FixBot
    2. Back Panel Removal: step 2, image 1 of 1
      • Flip the laptop upside down. Locate the two latches on both sides of the battery.
      Ask FixBot
    3. Back Panel Removal: step 3, image 1 of 3 Back Panel Removal: step 3, image 2 of 3 Back Panel Removal: step 3, image 3 of 3
      • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
      • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
      • Do not touch the metal connectors on the laptop and the battery.
      Ask FixBot
    1. Back Panel Removal, Back Panel Removal: step 4, image 1 of 1
      • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
      Ask FixBot
    2. Back Panel Removal: step 5, image 1 of 2 Back Panel Removal: step 5, image 2 of 2
      • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
      • Work your way around the border of the panel, releasing the rest of the clips.
      • Once all clips are released, lift the cover up and pull towards you.
      Ask FixBot
To replace the back panel, follow the steps in reverse.
2 other people completed this guide.
Austin Bons
1,131 Reputation
8 Guides authored
UC Davis, Team 2-2, Oliver Fall 2016 Member of UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 62
All Time: 8,898
