Up to 20% off select tools
Back Cover Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
128
All Time:
1,442
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide is a prerequisite to accessing the inside of the Zoomer Dino Boomer, where the battery, electronics, and pulley system are located. It is important to be gentle while opening the dinosaur since the top covering will still be attached to the electronic system via a wire.
    1. Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Power off Zoomer Dino Boomer before disassembly.
      • Remove the eight 9.3mm Phillips #1 screws.
      Ask FixBot
    2. Back Cover Replacement: step 2, image 1 of 2 Back Cover Replacement: step 2, image 2 of 2
      • Turn dinosaur over and hold upright.
      • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
      • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
      Ask FixBot
    3. Back Cover Replacement: step 3, image 1 of 3 Back Cover Replacement: step 3, image 2 of 3 Back Cover Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
      • Remove back cover.
      • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
      • Do not damage the wires or circuit board.
      Ask FixBot
Author
with
Desiree DesJardins
452 Reputation
2 Guides authored
USF Tampa, Team 16-1, Wollert Fall 2015 Member of USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 128
All Time: 1,442
