Back Cover Removal
Views: 5K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
106
All Time:
4,955
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Back Cover Removal
Introduction
Go to step 1 ↓
To gain access to many of the device components removal of the back cover is required.
Tools
    1. Back Cover Removal, Battery: step 1, image 1 of 1
      • Turn the laptop face down to expose the back.
      • Locate the battery.
      Ask FixBot
    2. Back Cover Removal: step 2, image 1 of 3 Back Cover Removal: step 2, image 2 of 3 Back Cover Removal: step 2, image 3 of 3
      • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
      • Push the latch on the right to the right to unlock the battery latch locking mechanism.
      • Push the battery latch on the left to the left to unlock the battery.
      Ask FixBot
    3. Back Cover Removal: step 3, image 1 of 2 Back Cover Removal: step 3, image 2 of 2
      • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
      • The battery will come free.
      Ask FixBot
    1. Back Cover Removal, Back Plate Removal: step 4, image 1 of 3 Back Cover Removal, Back Plate Removal: step 4, image 2 of 3 Back Cover Removal, Back Plate Removal: step 4, image 3 of 3
      • Turn the laptop over to place it top down.
      • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
      • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
      Ask FixBot
    1. Back Cover Removal, Optical Drive: step 5, image 1 of 2 Back Cover Removal, Optical Drive: step 5, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the single 3mm screw.
      Ask FixBot
    2. Back Cover Removal: step 6, image 1 of 2 Back Cover Removal: step 6, image 2 of 2
      • Rotate the laptop so that you have access to the optical drive.
      • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
      • Remove the drive.
      Ask FixBot
    1. Back Cover Removal, Hard Drive: step 7, image 1 of 2 Back Cover Removal, Hard Drive: step 7, image 2 of 2
      • Unscrew the hard drive.
      • There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
      • Carefully push the hard drive away from its port. This should not require substantial force.
      • Lift the hard drive out.
      • Some hard drives have a plastic tab, which can be lifted from to remove the hard drive.
      • Otherwise, take hold of opposite sides of the hard drive and lift the drive straight up.
      Ask FixBot
    1. Back Cover Removal, Back Cover Removal: step 8, image 1 of 2 Back Cover Removal, Back Cover Removal: step 8, image 2 of 2
      • Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
      • Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
      Ask FixBot
Monte Roden
465 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 106
All Time: 4,955
