Up to 20% off select tools
Back Case
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
111
All Time:
1,474
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Back Case
Tools
Introduction
Go to step 1 ↓
Are you trying to figure out what is wrong with your camera? This is a good place to start as it allows you to access everything in the camera that could possibly be wrong.
    1. Back Case, Battery: step 1, image 1 of 1
      • Orient camera to look directly at battery compartment side as shown.
      Ask FixBot
    2. Back Case: step 2, image 1 of 3 Back Case: step 2, image 2 of 3 Back Case: step 2, image 3 of 3
      • Locate the two latches on the battery compartment.
      • First, move the "lock" switch left to reveal red indicator.
      • Next, move the "cover latch" switch downward to reveal red indicator.
      • You have to move the switches in that order for the compartment to unlatch.
      Ask FixBot
    3. Back Case: step 3, image 1 of 2 Back Case: step 3, image 2 of 2
      • Allow the battery compartment latch to completely open.
      • Insert battery with the writing face up.
      • The bigger slot is for the battery. The smaller slot is for the memory card.
      • Battery not shown.
      Ask FixBot
    1. Back Case, Back Case: step 4, image 1 of 1
      • Orient the camera so you are looking at the bottom.
      • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
      Ask FixBot
    2. Back Case: step 5, image 1 of 1
      • Orient the camera so you are looking at the side plate.
      • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
      Ask FixBot
    3. Back Case: step 6, image 1 of 2 Back Case: step 6, image 2 of 2
      • Orient the camera so you are looking at the front plate.
      • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
      • Remove the "Olympus" plate.
      Ask FixBot
    4. Back Case: step 7, image 1 of 1
      • Remove face plate.
      Ask FixBot
    5. Back Case: step 8, image 1 of 3 Back Case: step 8, image 2 of 3 Back Case: step 8, image 3 of 3
      • Locate three small black screws inside of the battery compartment.
      • Remove the 3.85mm Phillips #00 screw on the far left side.
      • Remove the two 5mm Phillips #00 screws on the right side
      Ask FixBot
    6. Back Case: step 9, image 1 of 3 Back Case: step 9, image 2 of 3 Back Case: step 9, image 3 of 3
      • Orient the camera to be look at the top.
      • Remove the 5.4mm Phillips #00 screw on the top left side.
      • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
      • Pry off top button plate with black nylon spudger.
      Ask FixBot
    7. Back Case: step 10, image 1 of 2 Back Case: step 10, image 2 of 2
      • Rotate to bottom of camera and locate bottom latch.
      • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
      • Push firmly apart.
      • Some buttons might fall out.
      Ask FixBot
    8. Back Case: step 11, image 1 of 3 Back Case: step 11, image 2 of 3 Back Case: step 11, image 3 of 3
      • Orient the camera to the LCD screen side that is now wedged open.
      • Locate the white ribbon cable and pull out from motherboard.
      • Locate the brown ribbon cable and pull out from motherboard.
      Ask FixBot
Author
with
Larissa Knight
549 Reputation
5 Guides authored
Clemson, Team 7-2, Benson Spring 2016 Member of Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 111
All Time: 1,474
